Database Corruption
Server Version#: 1.14.1.5488
Player Version#: 3.77.4
I’ve noticed in my logs that I am getting the database corruption errors:
Soci Exception handled: sqlite3_statement_backend::loadOne: database disk image is malformed
The system seems to be working fine otherwise.
I took a copy of the DB and ran the fix that is in the forums but am not getting a clean result:
sqlite3 com.plexapp.plugins.library.db “DROP index ‘index_title_sort_naturalsort’”
sqlite3 com.plexapp.plugins.library.db “DELETE from schema_migrations where version=‘20180501000000’”
sqlite3 com.plexapp.plugins.library.db “PRAGMA integrity_check”
wrong # of entries in index index_statistics_media_on_timespan
wrong # of entries in index index_statistics_media_on_device_id
wrong # of entries in index index_statistics_media_on_account_id
wrong # of entries in index index_statistics_bandwidth_on_timespan
wrong # of entries in index index_statistics_bandwidth_on_device_id
wrong # of entries in index index_statistics_bandwidth_on_account_id
Any ideas what to investigate?
Thanks.
That is only the check. You didn’t run the actual fix.
D’Oh!
Yeah, the fixes worked. I was ocncerned with the “Wrong # of entries” statements and was thinking it was something unusual.
All fixed up now and logs are rolling clean.
Thanks.
I need help and can’t create a new post… when i run the DB checks and i get to this line:
sqlite3 com.plexapp.plugins.library.db "DROP index 'index_title_sort_naturalsort'"
An error is returned: Error: no such index: index_title_sort_naturalsort
I have a 300+MB database and plex is on the lates public release. I’m a plexpass member. Any help is appreciated.
PS: I ran the rest of the steps and then the repair, after the re-creation of the DB, it’s 4KB! :frowning:
the dump.sql is 297MB.
Thanks in advanced… i’m stuck without a working Plex server…
What happens if you just run the last step?
sqlite3 com.plexapp.plugins.library.db "PRAGMA integrity_check"
It returns this:
*** in database main ***
Page 34796: btreeInitPage() returns error code 11
Page 34795: btreeInitPage() returns error code 11
Page 34794: btreeInitPage() returns error code 11
Page 34793: btreeInitPage() returns error code 11
Page 34792: btreeInitPage() returns error code 11
Page 34791: btreeInitPage() returns error code 11
Page 34790: btreeInitPage() returns error code 11
Page 34789: btreeInitPage() returns error code 11
Error: database disk image is malformed
And then i run the repair steps and that’s when it’s 4KB in size. :frowning:
That is not an error I am familiar with.
Can you PM me a zip of your DB file so I can take a look?
Longshot: are there older backups in the ./Plex Media Server/Plug-in Support/Databases directory you can try an integrity check against?
If there are copy them to another location and try doing the checks against them.
