Yet another DB crash
Hi all,
New media is again no longer showing up
As we have (way too) many power cuts over here, I do not have many doubts about the cause
I have summarized the instructions already performed on my PMS a few months ago as follows:
sqlite3 com.plexapp.plugins.library.db “DROP index ‘index_title_sort_naturalsort’”
sqlite3 com.plexapp.plugins.library.db “DELETE from schema_migrations where version=‘20180501000000’”
Integrity check
sqlite3 com.plexapp.plugins.library.db “PRAGMA integrity_check”
Export DB
sqlite3 com.plexapp.plugins.library.db .dump > dump.sql
Rename the original, corrupted DB file
mv com.plexapp.plugins.library.db com.plexapp.plugins.library.db.original
Import the SQL dump back into a new DB file:
sqlite3 com.plexapp.plugins.library.db < dump.sql
Run another check to establish if repair was successful
Move these 3 files out to a safe place (outside of Plex’s data), just in case you want to revert it:
com.plexapp.plugins.library.db-shm
com.plexapp.plugins.library.db-wal
The integrity check reports the following:
[plex@plex Databases]# sqlite3 com.plexapp.plugins.library.db “PRAGMA integrity_check”
Error: no such collation sequence: naturalsort
My questions before starting the recovery:
  1. is it OK to systematically run both
  2. What is the meaning of that version/date 20180501000000 ?
Thanks!
Yes, this will remove the collation naturalsort, which otherwise would cause the error message ’ no such collation sequence: naturalsort
The second instruction will tell Plex server to restore this collation upon next start. By which time you’ll have already performed the repair procedure.
Ever thought about a UPS box? They get cheaper and cheaper.
Hi Otto
Thanks for the answer
And actually, I do have an old UPS, which I only need to put in place and to replace the fuse…
I should definitely put that fuse in my next investment budget…
Thanks again!
