Database Corruption
I might have the same problem. I cannot play movies from any client (web, Android phone, Android TV). All movie posters are gone except for a few probably locally cached on the respective devices. When I try to play/go to a movie I get that something went wrong or that the server is not accessible. A quick look in the log file gives many Got exception from request handler: std::bad_cast errors. I am running PMS 1.30.2.6563 on Unraid 6.11.0.
Plex Media Server Logs_2023-01-29_16-11-46.zip (4.6 MB)
Moved your post to the unraid & docker areas.
You’ve database corruption.
Use the PlexDBRepair utility to correct it.
You can restore from a backup, if available, or repair the current database.
See Scenario A & B in the readme file.
Jan 29, 2023 16:10:07.631 [0x148bad80faa0] ERROR - SQLITE3:0x80000001, 11, database corruption at line 88814 of [1b256d97b5]
Jan 29, 2023 16:10:07.631 [0x148bad80faa0] ERROR - SQLITE3:0x80000001, 11, statement aborts at 24: [update taggings set created_at = iif(typeof(created_at) in ('integer', 'real'), created_at, strftime('%s', created_at, 'utc'))] database disk image is malformed
Jan 29, 2023 16:10:07.632 [0x148bad80faa0] ERROR - Exception inside transaction (inside=1) (/data/jenkins/server/3524661465/Library/DatabaseMigrations.cpp:289): sqlite3_statement_backend::loadOne: database disk image is malformed
Jan 29, 2023 16:10:07.633 [0x148bad80faa0] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database disk image is malformed
Thank you for your help. It was indeed a corrupted database, and the repair function fixed it for me.
I can play from every platform except Plex.
I am looking at all of the solutions available and apparently I am screwed. I am not a programmer or coder.
@mvondracek
Suggest you continue the conversation in your original thread:
