my does the same thing her goes my logs
Plex Media Server Logs_2018-10-19_07-41-33.zip (5.6 MB)
I have moved this to a new thread. a. the previous was not related. b. It’s over a year old.
I am looking at your logs now. You are experiencing database locks (server overloaded)
Do you have PMS 1.13.4 which you can load on top of the existing?
If so, I would like you to compare the two. There have been a few reports of database issues with 1.13.8.
I have version 1.13.8.5395
What do you recommend I do because my server barley wants to load for me
I’ve got similar issues. See my post here: Cannot begin transaction. database is locked
even with Plex DBs on a RAMdisk, i see massive performance issues with my DB, to the point where I’m optimizing and running the DB repair on a cronjob to try to keep things clean. Even with that effort, my database is still slow, it’s still bloated, and it’s still causing issues - sometimes to the point of killing the PMS instance entirely. Any help would be appreciated.
I can try rolling back to test 1.13.4 using a Docker tag, and report back findings.
