Database optimization WARN and INFO log entries
Server Version#: 1.112.0.359-0d79a49f
Player Version#: 1.112.0
When I review “Plex Media Server.log” after running a database optimization, I see some WARN and INFO and I am wondering if there is some action I should take to resolve them? Specifically:
Feb 13, 2026 13:46:10.212 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db/DatabaseFixups/41DatabaseFixupsDeleteUnusedTagsAndTaggings] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/DatabaseFixups.cpp:239): 0.160000 seconds
Feb 13, 2026 13:46:10.353 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db/DatabaseFixups/35DatabaseFixupsConsolidatePeopleTags] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/DatabaseFixups.cpp:374): 0.130000 seconds
Feb 13, 2026 13:46:15.318 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:58): 4.950000 seconds
Feb 13, 2026 13:46:16.954 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:71): 1.390000 seconds
Feb 13, 2026 13:46:20.358 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:81): 3.400000 seconds
Feb 13, 2026 13:46:24.694 [140302291819320] WARN - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:94): 4.290000 seconds
Feb 13, 2026 13:46:29.970 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.972 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.973 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.975 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.977 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.980 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.981 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.983 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.984 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.985 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.986 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.987 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.988 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.989 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.990 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.991 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.992 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Feb 13, 2026 13:46:29.993 [140302291819320] INFO - [Req#242e3/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x80000001, 17, statement aborts at 63: [select * from metadata_items limit 1] database schema has changed
Completely ignore the INFO messages.
You can monitor if the warnings persist after waiting fo things to settle (there could still be some backlog of background tasks). If you still see I those later, see if they persist after a restart of your server.
