Strange errors in log - Redux - library.db
Server Version#: 1.28.1.6041
I’m seeing some errors in Plex Media Server.log regarding com.plexapp.plugins.library.db
Aug 09, 2022 09:36:20.262 [9852] WARN - [Req#b2/Database optimization/com.plexapp.plugins.library.db/DatabaseFixups] Held transaction for too long (E:\jenkins\server\3580694791\Library\DatabaseFixups.cpp:217): 0.171875 seconds
Aug 09, 2022 09:36:22.379 [9852] WARN - [Req#b2/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (E:\jenkins\server\3580694791\Library\FullTextSearch.cpp:58): 2.015625 seconds
Aug 09, 2022 09:36:23.205 [9852] WARN - [Req#b2/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (E:\jenkins\server\3580694791\Library\FullTextSearch.cpp:71): 0.703125 seconds
Aug 09, 2022 09:36:26.542 [9852] WARN - [Req#b2/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (E:\jenkins\server\3580694791\Library\FullTextSearch.cpp:81): 3.250000 seconds
Aug 09, 2022 09:36:29.962 [9852] WARN - [Req#b2/Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (E:\jenkins\server\3580694791\Library\FullTextSearch.cpp:94): 3.312500 seconds
Aug 09, 2022 09:36:33.931 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.932 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.934 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.935 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.937 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.938 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.940 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.941 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.942 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.944 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.945 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.946 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.948 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.949 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.950 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.951 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.953 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.954 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
Aug 09, 2022 09:36:33.955 [9852] INFO - [Req#b2/Database optimization/com.plexapp.plugins.library.db] SQLITE3:0x940122cf, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
I’ve done all the steps outlined here: Repair a Corrupted Database | Plex Support but the errors keep coming back.
They happen when I try to optimize the database from Plex Web UI.
I am afraid the process bails out before the database is optimized.
PMS is otherwise working fine.
Any clue how can I solve this?
Many thanks!
Nothing to solve, looks completely normal.
Thanks.
The lines Held transaction for too long and statement aborts at 58: [select * from metadata_items limit 1] database schema has changed sounded a bit ominous to me.
So the database optimization process runs as it should?
Those are fairly routine messages. Any time a query takes longer than expected (some low value in milliseconds) plex starts complaining about held transactions. The schema changes are normal during database upgrades and sometimes optimizations.
Many thanks!
Feel better now :slightly_smiling_face:
