Database problem ShieldTV
Server Version#:1.40.1.8251
I get a message there is a problem detected in core section/element from Plex Media Server (translated) and I should go here to share the log
Plex Media Server Logs_2024-04-18_10-15-49.zip (4.0 MB)
You are not alone, check it out:
As of now, there seems to be so solution. Maybe downgrading to an older version of PMS will fix the issue. It did not work for me though.
Downgraded Plex Server and that worked.
Crazy these things happening with Plex
Yep it’s a known issue that plex is broken currently.
