Thanks for the log files.
I didn’t realize it is Windows, which isn’t in my area of expertise at all .
What I did find, and very likely at the root of your problems is a number of networking problems
Curl error 6 is a DNS lookup failure (convert hostname to IP address)
Curl error 7 is can’t connect (because of the 6 above it)
PMS can’t connect to plex.tv at all “Unknown error”
I have no idea what is happening here but it’s profound.
@OttoKerner Can you perhap shelp here?
Aug 28, 2018 15:57:24.940 [7932] WARN - PubSubManager: Connection to 50.116.51.249 failed: Unknown error.
Aug 28, 2018 15:57:24.940 [7932] WARN - PubSubManager: Connection to 139.162.142.209 failed: Unknown error.
Aug 28, 2018 15:57:24.940 [7932] ERROR - EventSource: Retrying in 60 seconds.
Aug 28, 2018 15:57:27.442 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 15:57:41.732 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 15:57:55.106 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:07.110 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:19.126 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:31.245 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:43.273 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:55.277 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 82.94.168.54 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 45.79.195.99 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 45.79.11.43 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 50.116.51.249 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 139.162.177.42 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 139.162.115.125 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 139.162.215.242 failed: Unknown error.
Aug 28, 2018 15:58:55.440 [7932] WARN - PubSubManager: Connection to 172.104.59.31 failed: Unknown error.
Aug 28, 2018 15:58:55.441 [7932] WARN - PubSubManager: Connection to 184.105.148.98 failed: Unknown error.
Aug 28, 2018 15:58:55.441 [7932] WARN - PubSubManager: Connection to 45.33.75.206 failed: Unknown error.
Aug 28, 2018 15:58:55.441 [7932] ERROR - EventSource: Retrying in 120 seconds.
Aug 28, 2018 15:59:09.532 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 15:59:21.541 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 15:59:35.796 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 15:59:47.829 [12980] ERROR - Error issuing curl_easy_perform(handle): 7
Aug 28, 2018 16:00:02.105 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:00:16.364 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:00:31.998 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:00:46.301 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:01:01.925 [12980] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:01:02.493 [12980] WARN - OnConnect: No match for detailed movie version: 21269 MV000681660000
Aug 28, 2018 16:01:02.673 [12980] WARN - OnConnect: No match for detailed movie version: 8939 MV000408400000
Aug 28, 2018 16:01:22.115 [9348] ERROR - Error issuing curl_easy_perform(handle): 6
Aug 28, 2018 16:01:25.939 [7932] WARN - PubSubManager: Connection to 45.79.195.99 failed: Unknown error.
Aug 28, 2018 16:01:25.940 [7932] WARN - PubSubManager: Connection to 45.79.11.43 failed: Unknown error.
Aug 28, 2018 16:01:25.940 [7932] WARN - PubSubManager: Connection to 50.116.51.249 failed: Unknown error.
Aug 28, 2018 16:01:25.940 [7932] WARN - PubSubManager: Connection to 139.162.177.42 failed: Unknown error.
Aug 28, 2018 16:01:25.940 [7932] WARN - PubSubManager: Connection to 139.162.115.125 failed: Unknown error.
