I was experiencing no symptoms but just ran the auto check as a scheduled task to make sure everything was alright. I received the following output which is indicating to me that it is not alright.
Plex Media Server Database Repair Utility (Synology (DSM 7))
Version v1.0.8
[2023-06-13 10.38.18] Automatic Check,Repair,Index started.
[2023-06-13 10.38.18] Checking the PMS databases
Error relocating /lib/openhook.so: backtrace_symbols: symbol not found
Error relocating /lib/openhook.so: backtrace: symbol not found
Error relocating /lib/openhook.so: __syslog_chk: symbol not found
Error relocating /lib/libapparmor.so.1: __snprintf_chk: symbol not found
Error relocating /lib/libapparmor.so.1: __asprintf_chk: symbol not found
Error relocating /lib/libapparmor.so.1: __fprintf_chk: symbol not found
Error relocating /lib/libapparmor.so.1: __sprintf_chk: symbol not found
[2023-06-13 10.38.18] Check complete. PMS main database is damaged.
[2023-06-13 10.38.18] Check complete. PMS blobs database is damaged.
[2023-06-13 10.38.18] Exporting current databases using timestamp: 2023-06-13_10.38.18
[2023-06-13 10.38.18] Exporting Main DB
[2023-06-13 10.38.18] Error 127 from Plex SQLite while exporting com.plexapp.plugins.library.db
[2023-06-13 10.38.18] Could not successfully export the main database to repair it. Please try restoring a backup.
[2023-06-13 10.38.18] Repair failed. Automatic mode cannot continue. Please repair with individual commands
[2023-06-13 10.38.18] Starting PMS.
[2023-06-13 10.38.23] Started PMS
Those symbols not being found is because DSM has changed the access to the runtime libraries. I’ve not been able to figure out how to manually set PATH or LD_LIBRARY_PATH
what about this error @ChuckPa ? It ran fine through terminal and said the database was ok. just curious if i should just turn off the scheduled task if it is always going to fail. Thanks.
so when i exited the terminal session it asked if i wanted to clear temp files so i did. Obviously i did not do that when it ran through the scheduled task. Does that mean the log has been deleted? if not, where is it located?
[2023-06-13 12.36.18] Exporting current databases using timestamp: 2023-06-13_12.36.18
[2023-06-13 12.36.18] Exporting Main DB
Error relocating /usr/lib/openhook.so: backtrace: symbol not found
Error relocating /usr/lib/openhook.so: __syslog_chk: symbol not found
Error relocating /usr/lib/openhook.so: backtrace_symbols: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __sprintf_chk: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __snprintf_chk: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __strcpy_chk: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __memset_chk: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __asprintf_chk: symbol not found
Error relocating /usr/lib/libapparmor.so.1: __fprintf_chk: symbol not found
[2023-06-13 12.36.18] Error 127 from Plex SQLite while exporting com.plexapp.plugins.library.db
[2023-06-13 12.36.18] Could not successfully export the main database to repair it. Please try restoring a backup.
[2023-06-13 12.36.18] Repair failed. Automatic mode cannot continue. Please repair with individual commands
those are all runs today. 1st was scheduled task. Then terminal. Then scheduled task. DSM was not updated in between. Today was the first time the utility was ever run on my machine.
i just updated to update 6. ran the task and it has the same errors.
i cannot get 7.2 as its a staged roll out. Looks like you upgrade to the now removed versions that had some issues and there was some patch they made.
it weird because it doesn’t list it has beta when i pulled it up but then it had a reference to 7.2 beta.
either way, seems like dbrepair can’t be run as a scheduled task on newer releases. not a huge deal though as clearly not many people are doing it or it would have popped up sooner.
[Symptoms]
Plex SQLite process unable to run in Task Scheduler on DSM 7.2
[Steps to Reproduce]
1. Using ChuckPa/PlexDBRepair from github (URL below)
2. Start script on ssh console
3. Stop Plex, attempt to check databases
4. Observe /usr/libibapparmor.so.1 cannot be relocated due to symbol not found.
They were very anxious about getting as much info as I could provide.
DSM 7.2 is new/ending beta and this type problem is important (especially for their Plex team – yes, they have a Plex team) – to resolve quickly before it becomes more widespread
