In the UK, all HD channels are channel 101 and upwards and the majority of SD channels are 01 and upwards. Given for the most part the programme guide is the same for equivalent HD channels as SD ones, I have previously set the guide channel for an SD for the HD device channel. The reason for doing this is to enable the HD channels to appear at the top of the EPG. For example (square brackets shows the device channel number):
001 BBC1 [101]
002 BBC2 [102]
003 ITV [103]
004 Channel 4 [104]
etc
With the v1.25 releases of PMS, I’ve noticed that any channel that has a dash, for example, 001-9 is now put at the very end, rather than at the top as previous. Can this be changed to revert to the previous sort order, or, even better, allow the channel order to be set, in a similar way to the way you can change the order of the pinned hubs.
Many thanks.
