Deleted files not removed from library
The problem is still there, keeping the thread alive.
Hmm, it does seem logical to me that - if you have two versions of a file (versions, not editions) - Plex ought to attempt to send each file one by one. If one fails due to unavailable, assume the source is bad, and temporarily mark it as ā€œdeletedā€ then try another version.
Speculation on why not much has come to resolve this: This is a pretty specific case though. I doubt there are a lot of Plex users that keep multiple versions of movies, and those that do aren’t likely to have one of the versions on a removable media drive, and those that do aren’t likely to want Plex to not clean up the library with a scan when the drive is disconnected (bad phrasing).
People like this are out there, I see. But it seems like such a unique case this might not have come up before now. I wonder if the devs are aware of this…
This happens to everyone using a Radarr/Sonarr setup because upgrades to better versions of the material might happen automatically if it is so configured. It is not that I go and manually do it.
And I assume Plex knows about it because I did not open this thread, it is a split that a mod did from some other discussion. That why my tone in the first message is not the best. If I would have opened this thread I would have had a better tone and I might have explained the problem better. Actually I did opened a thread about it long time ago and it was ignored as usual.
