devices show with ip address
Any one know how or if is possible to show the devices under plex like the web player, Roku etc with an ip address where it is coming from? is that logged some where I could turn on?
Thanks again for all the help and an awesome project that plex has become.
Tom
This can be done with PlexPy
Check out
https://forums.plex.tv/discussion/169591/plexpy-another-plex-monitoring-program/p1
PlexPy, and if you can run Plex on a machine, you should also be able to run PlexPy on it as well. It will show you the local IP’s for anything that’s on your local network, not your WAN IP. Since you should probably know where those devices are within your local network, this shouldn’t be an issue. :slight_smile:
