Difference in viewing synopsis of movies and TV shows
"Baa" could leave the area with the same serial synopsis effect of what happens with the movies?
Today just happens with movies:
* inical screen, note that the synopsis is suppressed
after the user triggers the up key, the synopsis is complete
So I ask for you, it could happen with the screen to show the user can read the full synopsis?
If this is against the project of you could tell me how to implement here?
Best regards
Well, the the shown Movie page is the actual PrePlay screen - the last thing you see before starting the movie.
On the TVShow side, you shows kind of the show's top screen - you have to dig into the season, then select an Episode, then you would see the episode's PrePlay screen, very similar to the movie one...
I guess, we would have to look into that. -> Roidy?
Thanks for reply "Baa."
You're right, page of the episode is resembling that of the films making the same effect, but the synopsis of the episode up during the episode preview is possible.
This does not happen with a synopsis of the series, she is always suppressed.
If there was anything to see the full synopsis would be very cool.
the size of the synopsis is regulated by the header size.. and i think its not durable to se the full synopsis unless u move the header size all the way upp.. i have tried to fix this in my old themes but i did not get it working to show the full synopsis without interfering with the background image..
Thanks for the reply "stoffez".
I did not think the synopsis always be the show, but appear after a command to control or even a button "to see full synopsis".
You understand me?
Best regards
yes i understand the function u want, but i don't think its possible to view the full synopsis at all with or without command.. this is due to the Background image is suppressing the line and moves it down.. the same goes for the episode list.. as u can se you have the same issue there.. its suppressed.. this is due to the background image..
(i would not say that i am 100% right) but i am pretty sure cause i have been fiddling around a lot with this earlier..
the only way i could get it to show was to change the values and then it looked like this
You like to play with que huh?!
My intention is not so much the episode, but the synopsis of the series.
But thank you for holding this!
A big hug for you!
In which files you handled?
Thanks my friend!
the episode template and the series template unfortunately works the same way :(
season_list_fanart and Episode_fanart
I thought so!
Thanks!
Let me ask you a question, even with a samsung series 7 or 8 you have, you still use the ATV.
The PLEX client samsung do not like it?
big hug
I have a mac mini that i could run xbmc, or plex home theather on… In my opinion the atv is still the best way to run plex using plex connect… Fast, stable and customazible… Its also small and discrete, and i have programmed my orginal remote to function with the atv so all i need is 1 remote… Instead of 2-3 if i where using a home center… Cheers
Thanks!
"stoffez" could share these files here for me to test?
Big rug
