Different Channels on Different Devices
Im just starting to use the Live TV feature, but it is confusing. The shows that are playing are sometimes different depending on the device im using. For instance, im watching Better Call Saul on AMC Stories with both of my Rocu devices. On my Xbox its playing Mad Men. Whats with that? I only see one AMC channel, so why is it different? I noticed this before with another channel.
For some channels there are multiples, AMC appears to be one of them. You can always search and it will bring up if there is multiples.
I dont know where to search there is no option under live tv. If i search from the main search bar above the home link, the only results are from my personal library. I also scrolled through every channel and there is only one AMC.
The search on the Xbox app at least gives me results, but still only one AMC channel
I did my search on the web app using https://app.plex.tv/ and on my Apple tv I can see both channels when going to Plex Channels like you have, they are both between Hallmark and Walking Dead Universe. Not sure why you’re only seeing one. I just checked and they both show up under the “Hit TV” category as well.
Search has a hidden button that only appears when you select the box to type. A button appears on the right-end of the bar that lets you pick what “sources” you want the search bar to search. Turn on “Live TV on Plex”. This option only appears if you enable “Live TV” under “Online Sources” in your settings menu.
Some clients cannot use some types of DRM so those clients don’t have those channels.
