Digital Room Correction for PlexAmp?
PlexAmp has a central role in my music streaming.
Love it that the EQ with preloaded headphone profiles is available.
But what I really would love, is the option of a Digital Room Correction. Either via PlexAmp team, or licensed via Dirac? DRC software on the server, a Microphone plugged into a connected device, and stream test tones via the PlexAmp player through speakers - and let the magic happen :slight_smile:
Sounds easy when I write it like this :smiley:
Here’s what I’ve found…and I’m only playing 2-channel audio.
Take it from me, I was born in '72, had hearing so good I could hear
the 16KHz flyback transformer of a CRT (Cathode Ray Tube) on the other
side of a concrete block wall, so I know a “little bit” about audio. No BS.
First off, know what bitrate your Plex server is set to transcode into for audio/music streaming.
Mine is set to music, 192 kbps (kilo bits per second) in the OPUS Codec. Once you know this,
then you can transcode ALL of your audio to that codec and bitrate–takes the load off of your
server transcoding and it can stream NATIVELY!!! …ALL of the audio that I have hard transcoded
to OPUS (Native to PlexAmp) was originally a FLAC file…or DSD (Direct Stream Digital–RARELY!)
I switched from Apple’s AAC codec to OPUS as YouTube ALSO uses OPUS and it’s a VERY legitimate
format as it doesn’t exhibit the same sibilance in the high frequencies as the comparable bitrate
in the MP3 Format. Please forgive my long drawn out dissertation here!!! Ok. On to the process of
“flattening” your “sound space”-- I always do a physical auditory flattening with my ears using a
“pink noise” audio track…the higher quality codec you can find, the better. FLAC format if you
can get it, AAC would be my second choice, MP3 creates absolute high frequency sibilance junk in
the higher frequencies, especially below the 192 kbps sample rate. When I play the Pink Noise,
I have all types of audio processing dis-engaged whilst flattening the audio signal with the
“pink noise”–disengage DTS, disengage Dolby Atmos, and anything else. I recommend using the
highest resolution “pink noise” audio file you can find!!!..flatten all of the frequencies
using the base/system equalizer that you can so all of the frequencies sound the same
…none greater than another. Only after flattening the base EQ can you add back in the
other audio processors. Here’s “My Process”:
  1. I usually playback using a Samsung Android platform…either a phone or tablet as they
    natively include Dolby Atmos Audio Processing as part of the base Operating System Software.
  2. Disable System Dolby Atmos,
  3. Flatten EQ with Pink Noise File and Base system EQ
    -OR- PlexAmp EQ.
  4. After “flattening”, engage Dolby Atmos or DTS (on PC–most dynamic!)
    and listen and tweak your base EQ from there. ***ADDITIONALLY!!!–On my Samsung Android
    devices I also have a piece of software installed called “Sound °BEAUTIFIER°” which uses
    multiple controls so you can adjust and bring out multiple nuances in the music–compression and high frequency detail:
It’s quite a process, but when done correctly, it’s like “reverse engineering” YOUR sound system
to match what the audio engineer in the studio would have heard!!! Hopefully I haven’t made this
too complicated and you can find the “path” to Audio Excellence that suits your hearing capabilities!!!
–Every One’s Hearing is slightly different!!! Make Your Listening Experience PERSONAL!!!
CHEERS!
Here’s my take on this:
The fact that Plexamp has an EQ at all, is because it is primarily an app for mobile devices.
I don’t see that part of it becoming more sophisticated than that.
The above feature request doesn’t make much sense for a mobile device. It is more suitable to a fixed set up.
And because of that, I think it is reasonable to put things like EQ, room correction, and speaker correction outside of Plexamp and into the operating system’s audio pipeline.
That way all apps can benefit from it and you’ll have to measure a room only once (and not in every audio-playing app separately.
(Personally, I think even in the “mobile” use case, there should be EQ and other audio corrections done at the system level. For the same reasons as above. If done on the system level, it could even react to a change of audio device and apply a different set of corrections if e.g. a headphone is plugged in or the car stereo is connected per BT.)
Not even if this functionality were available “for free” via an open source software library. Even then you’d be battling with numerous challenges, which are all outside of the scope of a humble music player.
Quality of audio input, quality of microphone being the main ones. I don’t see any chance to even start supporting user-provided hardware for this. To get reliable (and supportable) results, Plex would need to have control over both (i.e. make/supply these themselves).
And last time I checked, Plex doesn’t plan to go into the hardware business any time soon.
Thanks @digitiz72 and @OttoKerner , appreciate your input.
I actually built a couple of RaspberryPi’s as the PlexAmp streamer. One connected to a headphone amp, the other to my 2 channel with speakers. I run it on my mobile as well, and indeed, room correction on a mobile device is not very useful - but with an amplifier setup, it changes everything.
Plex in the hardware would be an interesting decision, but I agree, unlikely, and for a software company it is a significantly different business model.
Licensing PlexAmp (such as Roon does) would be something else. Plenty of streaming amps out there - a lot of them Roon Ready. It would be nice if it was PlexAmped!
The calibration would be a challenge, but what is the pay-off? The room is a huge impact on the audio. It requires EQ (but unlike the current EQ, it needs to be 2 channel separated EQ), in that sense, PlexAmp is already a long way there. The next is a recording device, with a calibrated microphone. The microphones can be limited to a few models, or perhaps only one. A test tone generated/stored by Plex, and and the reference the software is targeted to hit.
Could it be a partnership with Dirac? (I’d pay for it).
I have an analyser, that provides me with directions to the EQ settings - which is a start, but I have no EQ in my amp, and I am not going to introduce one in the chain- unless it is digital.
PlexAmp was for me the reason to purchase Plex - I take the movie and tv server as a bonus. PlexAmp by far has been the best streaming option for music for me by far.
Get a MiniDSP 2x4HD + a UMIK, run tests with Room EQ Wizard (free), and call it done.
From what I understand, this should now be supported with the newly released version of Plexamp.
I am just speculating, but i think OP wants the test signals to be tested for sound quality - so if they were expecting certain sound characteristics via their EQ, is that what they actually get based on the environment, and if not, it would auto apply correction to the EQ accordingly??. The new feature is ‘just’ timings for multi-room. Same basic premise though.
