I’ve just installed RasPlex on a Pi2 1Gb (so it’s the latest version 1.8.0)
I’ve used plex server on a local Linux box for some years (that too is up to date) and I have iOS clients and Amazon Firestick client. All working, no problems.
I find the Firestick client sometimes problematic. It’s mostly fine but just occasionally it can’t keep up with playback. There’s a slight stutter before it carries on ok. Obviously this uses Wifi as there is no ethernet on this device. In the settings, the “Local Network” bandwidth is set to 20Mbps.
So I thought that I might fire up the old Raspberry (which has ethernet of course) on my gigabit LAN and put the whole bandwidth business to bed. However, once set up, i find all movies buffer immediately, play for a couple of seconds, buffer again, and so on. The setup is “Direct Play”, but even when I set it as low as 1Mbps I get the same thing. The only way I can get anything to work smoothly is to turn on “Force Transcoding”…which, to my mind, kinda defeats the object of direct play.
So, if my Wifi firestick is working, is there anything obvious I should be looking at why my ethernet should not be?
(Of course, I can play these movies directly over the network on a PC just fine with, say, VLC).
Sounds like rasplex is trying to reproduce something that a raspberry doesnt support natively
please paste the movie file info so i can have a look at the codecs and bitrate used
I was hoping to find you were using an unsupported format that forced rasplex to use software rendered or a buffering problem but it all seems ok
you could be hitting a buffer limit, try increasing it and disabling ffmpeg avio in the advance video preferences
you can also try omxplayer hardware acceleration as mmal can be sometimes choppy
also stupid as it is a slow sd card can result on constant buffering
Thanks for the continued responses. Sorry, I haven’t been on here for a couple of weeks.
I’ve been using Plex on Pi since I reported this and with no problems at all. I was unfortunate in that the problem was/is with just that one file (or at least, that one file so far). It was an incredible coincidence that that was the first file we started watching after installation! Everything else has been totally fine. So maybe I’ll just recode it and see if that sorts it.
There is nothing non-standard about my installation, network, nas, pi or plex…so if no-one else is having trouble, it would seem to point to the file or files. That’s my logic anyway
