Server Version#: 1.16.5.1488
Player Version# Plex for Tizen: 4.1.1
Tizen Version#: 3.0
If I connect a HDD directly to the TV it plays the HVEC without problem and my 5.1 audio system receives the signal without problem.
If I play it with plex, It converts it to x264, constantly buffering, all the settings on the TV are in Original. Any idea how can I achieve direct play for video at least?
I tried setting the audio in plex to TrueHD and AC3 5.1, still transcodes the video.
Plex player is configured as default: allow direct play and direct stream, and all quality options set to original
Example file info:
- Codec HEVC
- Bitrate 15658 kbps
- Bit Depth 10
- Chroma Subsampling 4:2:0
- Color Primaries bt2020
- Color Range tv
- Color Space bt2020nc
- Color Trc smpte2084
- Frame Rate 23.976 fps
- Height 1600
- Level 5.1
- Profile main 10
- Ref Frames 1
- Width 3840
- Display Title 4K (HEVC Main 10 HDR)
- Codec TRUEHD
- Channels 8
- Bitrate 3797 kbps
- Language English
- Audio Channel Layout 7.1
- Bit Depth 24
- Sampling Rate 48000 Hz
- Display Title English (TRUEHD 7.1)
- Codec AC3
- Channels 6
- Bitrate 448 kbps
- Language English
- Audio Channel Layout 5.1(side)
- Display Title English (AC3 5.1)
- Codec AC3
- Channels 2
- Bitrate 192 kbps
- Language English
- Audio Channel Layout stereo
- Display Title English (AC3 Stereo)
- Codec PGS
- Bitrate 33 kbps
- Language English
- Header Compression true
- Title English SDH
- Display Title English (PGS)
