Disable option to Ignore Articles/Tokens By Default.
Hello,
I would like to request a feature, pretty much the only problem I have with the software is the inability to remove the default setting thats removes "The" as a prefix for a movie.
In XBMC they call it ignoring articles, and it is enabled by default but I would like to request a simple feature to turn this option off, or at the very least the ability to update the "Sort_Title" field with the "Title" information.
Plus it looks like you used to be able to disable this option via advancedsettings.xml or on a Mac easily. My research concluded this option is no longer available to disable.. correct?
If there is a way to disable it, then for the love of god could someone please tell me how.. And I know I can update the "Sort_Title" Manually and add "The" back, but... come on, I have like 95Movies with the in the title. and if for some reason I have to re-populate the database then I will have to do that work all over again.
Thank you much,
Early 2021 clean-up: implemented (advanced/hidden server setting ArticleStrings)
