Discovery still slipping through
When i use web, once i have searched for a movie, then select it, it goes straight to my local details page. if i do the same for iOS (no idea if other ‘new experience’ apps does this too), but it first loads the ‘discover’ details page for that movie. depending how quick it is able to redirect, it then either sends me to my local version, or makes me hit the library button, and then another to select my actual library, and then load the local details. I have all discovery off, and search is blocking everything that is not on my server. I say it like this, as i can’t help have the feeling that search now always searches discovery first, then does some cross referencing magic - although i don’t know this for sure. However, it then seems the default is to always download the discovery page, and then try to switch if you have it local or block. Trouble is, it is so slow, you not only see the trick fail, it stays long enough to interact with it.
