Discrepancy with number of libraries being shared
I have a discrepancy in my User settings which shows that I am sharing 6 libraries with a friend, even though I only have 5 checked. Even when I uncheck all and save, it still says I am sharing 1 library.
How do I know that I am not unknowingly sharing a library with a user that I don’t want to be.
It is probably just a glitch.
I’d try toggling one library, save and exit this browser window. Then come back with a fresh browser session and revert the change.
This may fix it.
This may fix it.
This did not fix it.
Are you sharing from more than one server with the user?
The number 6 might be the overall number of shared libraries, across servers.
No, this is the only server I have.
Have you asked your friend what libraries they see?
Currently.
Have you ever erased old servers from Settings - Devices ?
If you shared with him earlier and the old server is still in the cache on plex.tv, then effects as this are possible.
@OttoKerner said:
Currently.
Not that I recall. I’ve only ever had this one server. I did use CloudSync for a bit, and did share that with this friend, but no longer use it. That same CloudSync was shared with other friends as well, but their ‘library totals’ match up.
Yes, waiting for a reply.
How many servers show up for you when you go to
Settings - Devices - Servers
He only sees the 5 I show.
This was the solution. I had another server listed there. That server was setup on my laptop over the summer (at a cabin) as a temporary solution to a problem. Completely forgot about it.
All fixed! Thanks guys!
