Ok, I ran that and it didn’t return anything. I am not sure if that is a good or bad sign lol
That’s a good sign!
Linux is terse.
Think of our parents; No loud voices means all is good! LOL
Now. what’s this about not finding a service file?
How is plex installed? Downloaded from the Ubuntu store or Plex.tv directly?
Downloaded from Ubuntu
that explains it. It will be a bear in that form.
May I suggest, which won’t hurt your data in any way but make this, and support tasks easier,
- Uninstall that snap package you got from Ubuntu
- Go to plex.tv/downloads
- Get the 64 bit Linux version for Ubuntu (DEB packaging)
- As you download it, it will give you the choice to install or save. That choice is yours.
Done!
When I launched it though this is what I got from Firefox:
Unable to connect
Firefox can’t establish a connection to the server at localhost:32400.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web
NO problem. I suspected that.
- In that Plex/Web browser – Upper right corner – Sign out
- Open an Incognito window
- In that window, go to address http://127.0.0.1:32400/manage
- Now you should be able to talk to it.
If not, sudo systemctl start plexmediaserver and repeat step #3 again.
I tried both but still had the same results. do i need to restart system after download?
No. We can force it to reset to a ‘new’ (unowned) state.
The reset sequence
sudo systemctl stop plexmediaserver
cd "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server"
mv Preferences.xml Preferences.xml-old
Now we start it gain and perform most of a 'fresh install but not all.
- systemctl start plexmediaserver
- open http://127.0.0.1:32400/web (the normal address)
- It will ask to claim & start setting up as if new
- Give this a new, temporary name to avoid confusion.
- DO NOT create new library sections. SKIP this step
- Proceed normally through the rest of setup
- When you arrive at the dashboard, anything previously created will be there.
If this fails:
sudo tar cf /tmp/Plexlogs.tar.gz "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs"
Please attach that /tmp/PlexLogs.tar.gz here for me to see what happened.
otherwise:
- Settings - Authorized devices.
- Servers dropdown
- REMOVE the old server
- Go to “Settings - Server - General - Show Advanced”
- Change the temporary friendly name we assigned and give it its old name again.
terminal returned this:
# mv: cannot stat ‘Preferences.xml’: No such file or directory
I ran the logs as requested and it returned this:
tar: Removing leading `/’ from member names
ok that’s good so far. Let’s see what it has.
May I have thar tar.gz file attached here (give it a second to upload before pressing Reply)
I cannot find the file for some reason. I promise I have used this computer for the lats year
- How long have you used Linux?
- Did you look in
/tmp?
Well only the one year but I am still learning for sure. I did not look in the tmp file lol I was looking here:
I am an idiot. I found the file now but it is 67.3 MB
It says that that size file cannot be uploaded
Plexlogs.zip (4.4 MB)
It’s trying to zip the whole Plex Media Server directory.
Let’s try that again?
sudo tar cfz /tmp/PlexLogs.tar.gz "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs"
you can copy/paste the above
PlexLogs.tar.gz (4.2 MB)
That time it worked. I must have entered it wrong the first go round
Perfect!.
When possible, I give Copy/Paste commands when I’m quoting like that.
I’ll go through the logs now.
You have success on 3 of the 4 drives! Are you referencing it yet within Plex?
Jul 17, 2019 21:47:54.425 [0x7f3494ff9700] DEBUG - Read configuration for [com.plexapp.plugins.WebTools], had 1 prefixes
Jul 17, 2019 21:47:54.426 [0x7f34b57fa700] DEBUG - Starting scheduled updates, every 3600 seconds
Jul 17, 2019 21:47:54.426 [0x7f34b57fa700] INFO - Refreshing paths watched by LibraryUpdateManager
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.1/Movies
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.2/Movies.2
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.3/Movies.3
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.1/TV Shows
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.2/TV Shows.2
Jul 17, 2019 21:47:54.427 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.2/Workout
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.1/XXX
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.2/XXX.2
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.1/YouTube
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - LibraryUpdateManager will start watching /disks/Plex.2/YouTube.2
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - [Notify] Initializing.
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - Done waiting for all plug-ins to start.
Jul 17, 2019 21:47:54.428 [0x7f344d7fa700] DEBUG - [Notify] Waiting for inotify notifications...
This confirms it is finding your movies and TV
Jul 17, 2019 21:47:54.428 [0x7f34b57fa700] DEBUG - PluginRepository::setStartState: 3, complete
Jul 17, 2019 21:47:54.428 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies"
Jul 17, 2019 21:47:54.428 [0x7f3497fff700] DEBUG - Downloading document http://127.0.0.1:32400/:/plugins/com.plexapp.agents.imdb/prefs
Jul 17, 2019 21:47:54.428 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons European Vacation"
Jul 17, 2019 21:47:54.428 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons European Vacation/Subtitles"
Jul 17, 2019 21:47:54.429 [0x7f3497fff700] DEBUG - Starting file watcher for com.plexapp.agents.imdb
Jul 17, 2019 21:47:54.429 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Spy Kids 2 Island of Lost Dreams"
Jul 17, 2019 21:47:54.429 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Cinderella (1950)"
Jul 17, 2019 21:47:54.429 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Vegas Vacation"
Jul 17, 2019 21:47:54.429 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Vegas Vacation/Subtitles"
Jul 17, 2019 21:47:54.430 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons Vacation"
Jul 17, 2019 21:47:54.430 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons Vacation/Subtitles"
Jul 17, 2019 21:47:54.430 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons Christmas Vacation"
Jul 17, 2019 21:47:54.430 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/National Lampoons Christmas Vacation/Subtitles"
Jul 17, 2019 21:47:54.430 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Spy Kids 3 Game Over"
Jul 17, 2019 21:47:54.431 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Cinderella (2015)"
Jul 17, 2019 21:47:54.431 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Spy Kids"
Jul 17, 2019 21:47:54.431 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Vacation"
Jul 17, 2019 21:47:54.431 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/Vacation/Subtitles"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/Movies/The Grinch"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap/Season 03"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap/Season 01"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap/Season 04"
Jul 17, 2019 21:47:54.432 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap/Season 02"
Jul 17, 2019 21:47:54.433 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Quantum Leap/Season 05"
Jul 17, 2019 21:47:54.433 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Sons of Anarchy"
Jul 17, 2019 21:47:54.433 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Sons of Anarchy/Season 06"
Jul 17, 2019 21:47:54.433 [0x7f34b6ffd700] DEBUG - [Notify] Now watching "/disks/Plex.1/TV Shows/Sons of Anarchy/Season 03"
What are we missing?
All of those logs are before we moved to our new house in August. Since then it hasn’t accessed anything. When I go into plex the it sees the server but there are no movies, shows, or music. When i try to create a library and rebuild it it doesn’t see the files at all. The “/disks” file folder that used to appear is no longer there
