Server Version#: 1.15.2.793
Firs time post so correct if wrong place/format
Was working fine for couple months , suddenly(2 weeks now) stopped playing some .mkv , even .avi
Win8.1 VM, 8Gb RAM, 8core AMD, was working on v1.14.1.5488, stopped, updated to latest-no luck, uninstalled/reinstalled, current-Version 1.15.2.793-still no luck.
All TV sets(x4) - Samsung, different models
Most bizarre!
Isn’t it suppose to be: “can’t play as is - transcode” ?
Apr 01, 2019 20:01:20.074 [3700] DEBUG - MDE: E10 - The Dream: no direct play video profile exists for http/mkv/hevc
Apr 01, 2019 20:01:20.074 [3256] DEBUG - TimelineClient: request returned 200
Apr 01, 2019 20:01:20.074 [3700] DEBUG - MDE: E10 - The Dream: no direct play video profile exists for http/mkv/hevc/opus
Apr 01, 2019 20:01:20.074 [3700] DEBUG - MDE: E10 - The Dream: no remuxable profile found, so video stream will be transcoded
Apr 01, 2019 20:01:20.090 [3700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Apr 01, 2019 20:01:20.090 [3700] DEBUG - Scaled up video bitrate to 3388Kbps based on 4.500000x fudge factor.
Apr 01, 2019 20:01:20.090 [3700] DEBUG - Codecs: testing aac_mf (encoder)
Apr 01, 2019 20:01:20.090 [3700] DEBUG - MDE: Cannot direct stream audio stream due to codec opus when profile only allows aac
Transcoding take no place.
Error returned by device(TV) differ per device: unsupported file format, check network connection(LAN, Ethernet, all static IP’s)
Same time playing on PC’s - no issues, transcoding.
Sound s like profile issue(all devices get: DEBUG - Device at 192.168.1.xx will use Samsung SmartTV profile), but i change nothing, so why is that?
Let me know if more detail needed.
Thanks in advance.
