Transcoding not working - I must be missing something
Hey guys,
I don't know what i did, but somehow after installing a few things, one of which is the .26 release, trans-coding stopped working and now i can only see files naively supported by the device  in this case my Sony Bravia EX650.
Can anyone point me in the right direction?
Hey guys,
try to play something that is forced to transcode and check the server and DLNA logs...
http://wiki.plexapp.com/index.php/PlexNine_Tips_and_Tricks#Plex_Log_Files
I get the error
[FILE NAME]: avi/mpeg4/mp3 is not a supported directplay video profile
Same with avi/mpeg4/ac3 and mkv/h264/dca.
If it helps i have followed this profile instructions previously:
http://forums.plexapp.com/index.php/topic/45145-sony-bravia-2012-profile/?hl=%2Bbravia+%2B2012+%2Bprofile
I get the error
that's not an error, it is just telling you your media is not direct play capable...
Valid point. Although i was able to play it for 6 months until it stopped working and i cant figure out why.
post the logs, post your profile...
I'm having the same issue .26 doesn't seem to want to transcode. Also a bravia. My dlnaclientprofiles.xml is:
<?xml version="1.0" encoding="utf-8"?>          Metadata/               Plug-in Support/        Scanners/
tarus:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server$ nano dlnaclientprofiles.xml
          http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000
and the log says
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - Starting Plex DLNA Server 0.9.7.26-47ad65c...
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - Unique device name = 433cef2c-aba5-10dc-72d2-77733a688314
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - DLNA server port: 32469
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - PMS: http://127.0.0.1:32400/
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - MyPlex: https://my.plexapp.com/
May 20, 2013 22:43:05 [0x7f04b7d93740] INFO - DB schema for com.plexapp.dlna changed from 5 to 6.
May 20, 2013 22:43:05 [0x7f04b7d93740] DEBUG - Loading com.plexapp.dlna is complete (success=1)
May 20, 2013 22:43:06 [0x7f04b7d93740] DEBUG - Reading system DLNA profiles
May 20, 2013 22:43:06 [0x7f04b7d93740] DEBUG - DLNA device discovery enabled every 60 seconds
May 20, 2013 22:43:06 [0x7f04b7d93740] DEBUG - Initialization complete
May 20, 2013 22:43:07 [0x7f049a7fc700] DEBUG - OnGetProtocolInfo from 192.168.1.74
May 20, 2013 22:43:07 [0x7f049a7fc700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:39 [0x7f04997fa700] DEBUG - OnBrowseDirectChildren for '0' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:39 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:39 [0x7f04997fa700] DEBUG - Mapped object 0 to  part 0 on server
May 20, 2013 22:48:39 [0x7f04997fa700] DEBUG - OnBrowseDirectChildren returning success with 3 objects of 3 total
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren for '94467912-bd40-4d2f-ad25-7b8423f7b05a' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - Mapped object 94467912-bd40-4d2f-ad25-7b8423f7b05a to  part 0 on server
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - Downloading document http://127.0.0.1:32400/library/sections
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - Loading CAs from '/usr/lib/plexmediaserver/Resources/cacert.pem'
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/sections
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - Caching document http://127.0.0.1:32400/library/sections
May 20, 2013 22:48:40 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren returning success with 8 objects of 8 total
May 20, 2013 22:48:40 [0x7f0498ff9700] DEBUG - GET for http://192.168.1.10:32469/proxy/ba7c8dac9650180ec83b/albumart.jpg
May 20, 2013 22:48:40 [0x7f0498ff9700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:40 [0x7f0498ff9700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2F:%2Fresources%2Fmovie%2Epng&width=512: HTTP/1.0 200
May 20, 2013 22:48:40 [0x7f0498ff9700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:40 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/303ae750748f5d09b729/albumart.jpg
May 20, 2013 22:48:40 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:40 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2F:%2Fresources%2Fshow%2Epng&width=512: HTTP/1.0 200
May 20, 2013 22:48:40 [0x7f04997fa700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren for 'a04d63776db06b32910f' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - Mapped object a04d63776db06b32910f to /library/sections/2 part 0 on server http://127.0.0.1:32400/
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - Downloading document http://127.0.0.1:32400/library/sections/2
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/sections/2
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - Caching document http://127.0.0.1:32400/library/sections/2
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - [PERF] Slowest insertObjectID in 10.000000 ms.
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - generateForContainer - ignoring special directory inside container /library/sections/2 (21)
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren returning success with 10 objects of 13 total
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren for 'a04d63776db06b32910f' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 10 + 10
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - Cache hit for document http://127.0.0.1:32400/library/sections/2
May 20, 2013 22:48:41 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren returning success with 3 objects of 13 total
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren for '1eb5add5b76c7434d455' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - Mapped object 1eb5add5b76c7434d455 to /library/sections/2/all part 0 on server http://127.0.0.1:32400/
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - Downloading document http://127.0.0.1:32400/library/sections/2/all
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/sections/2/all
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - Caching document http://127.0.0.1:32400/library/sections/2/all
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - [PERF] Slowest insertShortKey in 10.000000 ms.
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren returning success with 10 objects of 19 total
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren for '1eb5add5b76c7434d455' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 10 + 10
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - Cache hit for document http://127.0.0.1:32400/library/sections/2/all
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - [PERF] Slowest TransactionScope in 10.000000 ms.
May 20, 2013 22:48:43 [0x7f049a7fc700] DEBUG - OnBrowseDirectChildren returning success with 9 objects of 19 total
May 20, 2013 22:48:43 [0x7f0499ffb700] DEBUG - GET for http://192.168.1.10:32469/proxy/b751d05eb079f9ba39d0/albumart.jpg
May 20, 2013 22:48:43 [0x7f0499ffb700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:43 [0x7f0499ffb700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F435%2Fthumb%2F1361533739&width=512: HTTP/1.0 200
May 20, 2013 22:48:43 [0x7f0499ffb700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/600133178cda06ac6278/albumart.jpg
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F294%2Fthumb%2F1353490890&width=512: HTTP/1.0 200
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/22062e370e0c117295f0/albumart.jpg
May 20, 2013 22:48:44 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F374%2Fthumb%2F1353982313&width=512: HTTP/1.0 200
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/ff170774ce8439e4d04d/albumart.jpg
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F22%2Fthumb%2F1364000146&width=512: HTTP/1.0 200
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/b22f0abf9f18065e0484/albumart.jpg
May 20, 2013 22:48:45 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F954%2Fthumb%2F1360158962&width=512: HTTP/1.0 200
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/2a2c83fe087a93e1e03a/albumart.jpg
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F797%2Fthumb%2F1356360171&width=512: HTTP/1.0 200
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/b5097e5b82d012f49bdc/albumart.jpg
May 20, 2013 22:48:46 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F513%2Fthumb%2F1354796265&width=512: HTTP/1.0 200
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/ddf2eb56e1bf1327e782/albumart.jpg
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F19%2Fthumb%2F1367798411&width=512: HTTP/1.0 200
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - OnBrowseDirectChildren for '5873ac6510682fff8f64' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Mapped object 5873ac6510682fff8f64 to /library/metadata/1036/children part 0 on server http://127.0.0.1:32400/
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/1036/children
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/1036/children
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/1036/children
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - OnBrowseDirectChildren returning success with 4 objects of 4 total
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - GET for http://192.168.1.10:32469/proxy/27f14dd41bb4dfcc75bf/albumart.jpg
May 20, 2013 22:48:47 [0x7f04997fa700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F1036%2Fthumb%2F1366033314&width=512: HTTP/1.0 200
May 20, 2013 22:48:48 [0x7f0498ff9700] DEBUG - GET for http://192.168.1.10:32469/proxy/307bfc05847e4eff9717/albumart.jpg
May 20, 2013 22:48:48 [0x7f0498ff9700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:48 [0x7f0498ff9700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F1080%2Fthumb%2F1366103224&width=512: HTTP/1.0 200
May 20, 2013 22:48:48 [0x7f0498ff9700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:48 [0x7f049a7fc700] DEBUG - GET for http://192.168.1.10:32469/proxy/6c624914ce08775a93a5/albumart.jpg
May 20, 2013 22:48:48 [0x7f049a7fc700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:48 [0x7f049a7fc700] DEBUG - Proxied GET to http://127.0.0.1:32400/photo/:/transcode?format=jpg&height=512&url=http:%2F%2F127%2E0%2E0%2E1:32400%2Flibrary%2Fmetadata%2F1057%2Fthumb%2F1366041039&width=512: HTTP/1.0 200
May 20, 2013 22:48:48 [0x7f049a7fc700] DEBUG - Responding HTTP/1.1 200
May 20, 2013 22:48:49 [0x7f0499ffb700] DEBUG - GET for http://192.168.1.10:32469/proxy/eb996a2c5e1d22391573/albumart.jpg
May 20, 2013 22:48:49 [0x7f0499ffb700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - OnBrowseDirectChildren for '458338713ccb184506f7' with filter 'dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo' and sort '', paged as 0 + 10
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Mapped client to profile Sony Bravia 2011 using header av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Mapped object 458338713ccb184506f7 to /library/metadata/1057/children part 0 on server http://127.0.0.1:32400/
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/1057/children
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/1057/children
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/1057/children
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/1059,1058,1061,1060,1063,1062,1064,1065,1067,1068,1066,1072,1070,1071,1069,1075,1076,1077,1074,1073,1078,1079
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/1059,1058,1061,1060,1063,1062,1064,1065,1067,1068,1066,1072,1070,1071,1069,1075,1076,1077,1074,1073,1078,1079
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/1059,1058,1061,1060,1063,1062,1064,1065,1067,1068,1066,1072,1070,1071,1069,1075,1076,1077,1074,1073,1078,1079
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E01 - The Purple Piano Project: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E02 - I am Unicorn: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E03 - Asian F: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E04 - Pot O' Gold: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E05 - The First Time: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E06 - Mash Off: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E07 - I Kissed a Girl: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E08 - Hold On To Sixteen: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E09 - Extraordinary Merry Christmas: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E10 - Yes/No: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E11 - Michael: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E12 - The Spanish Teacher: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E13 - Heart: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E14 - On My Way: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E15 - Big Brother: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E16 - Saturday Night Glee-ver: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E17 - Dance With Somebody: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E18 - Choke: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E19 - Prom-asaurus: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E20 - Props: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E21 - Nationals: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] INFO - S03E22 - Goodbye: mkv/h264/dca is not a supported directplay video profile
May 20, 2013 22:48:49 [0x7f049b7fe700] DEBUG - OnBrowseDirectChildren returning success with 10 objects of 22 total
These have been working up until updating this evening...
Don't know if this would make any difference, but the DLNA profiles are now separated out into individual XML files in the latest versions of Plex Server:
C:\Program Files\Plex\Plex Media Server\Resources\Profiles
There is a profile file in there that says "Sony Bravia 2011" which looks a bit different to the profile you included above - I would think that Plex is using this slightly different profile instead of yours in the dlnaclientprofiles.xml
It looks like the profile location change from the app data folder. I'll move mine and see if it works. Thanks for the replies guys, I havent been on in a while.
Works like a charm again. The profile needs to be in this location:
Thanks everyone for all the help!
Hey guys,
Can someone please share a currently working profile for BRAVIA KDL-24EX320 (Sony Bravia 2011)?
