Server Version#:1.18.1.1973
Player Version#: several / all
After reboot DLNA server does not sart correctly
- All clients can not see the server
- After “sudo service plexmediaserver stop” and “start” (“restart” option got lost after last upgrade) DLNA is working as intended again!
- “Normal” plex server service is running after reboot and can be used
Anomalies in the log file After reboot:
sudo journalctl -xe | grep plex
link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
^^ does not appear any more after restarting service plexmediaserver
however: mii-tool eth0
eth0: negotiated 1000baseT-HD flow-control, link ok
service plexmediaserver status:
Active: active (running)
Exception AttributeError: “‘ZipArchive’ object has no attribute ‘_zip’” in <bound method ZipArchive.del of <Framework.components.data.ZipArchive object at 0xb24cc3d0>> ignored
