i tried plex htpc when it first came out but although the docs said i could send realtime parameter adjustments to mpv’s playing video (specifically, i wanted to adjust the video zoom level/parameter), everything i tried didn’t work
did the plex devs fix this?
has anyone actually got realtime mpv adjustment commands to work (e.g. using autohotkey to map a keyboard key combo to adjust plex htpc’s mpv video zoom level in realtime)?
Ok, so I finally figured out that you were probably talking about the ‘inputmaps.md’ file (please kindly remember that specific file name, thx).
I’ve now re-tried with the very latest Plex HTPC (1.3.1…) and Plex Media Server (on my Server PC)
And performed these steps:
Copied keyboard.json from “C:\Users\sahud\AppData\Local\Plex HTPC\inputmaps\default” into “C:\Users\sahud\AppData\Local\Plex HTPC\inputmaps”
Edited this line in that copied file "P": "play_pause",
Made it read "P": "mpv:set video-zoom=-2", and saved it
Launched Plex HTPC
Result = unfortunately doesn’t make the P keyboard key adjust the zoom level of video playing in Plex HTPC (actually it stops the P key from doing anything at all)
