Docker linuxserver/plex crash and plex media server is not accesible
Server Version#: 1.32.0.6973
Player Version#: Web 4.100.1
I have this docker image linuxserver/plex and when there are a lot of people connected, docker service crash and server is not accesible.
These are the logs:
2023-04-23 21:15:33,112 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 843, in handle_request
    result = f(**d)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/System.bundle/Contents/Code/agentservice.py", line 1082, in media_get
    data = HTTP.Request(media_url, cacheTime=0).content
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 300, in ElementFromString
    check_size(string, max_size)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 22, in check_size
    if len(data) > max_size:
TypeError: object of type 'NoneType' has no len()
2023-04-23 21:15:33,118 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
2023-04-23 21:15:59,772 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F1008636%3Flang%3Des&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_0560888d770c7b4e6b335347444122f5f09fb001
2023-04-23 21:15:59,779 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-04-23 21:15:59,780 (7ff41ea98b38) :  CRITICAL (storage:60) - Exception reading file /config/Library/Application Support/Plex Media Server/Metadata/Movies/e/ca3ad0980077dfbd4f2024364d2a14b8b73ce2d.bundle/Contents/_combined/Info.xml (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/storage.py", line 55, in load
    f = open(filename, mode)
IOError: [Errno 2] No such file or directory: '/config/Library/Application Support/Plex Media Server/Metadata/Movies/e/ca3ad0980077dfbd4f2024364d2a14b8b73ce2d.bundle/Contents/_combined/Info.xml'
2023-04-23 21:15:59,781 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
2023-04-23 21:15:59,782 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
2023-04-23 21:17:15,610 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F1008636%3Flang%3Des&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_0560888d770c7b4e6b335347444122f5f09fb001
2023-04-23 21:17:15,610 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-04-23 21:17:15,611 (7ff41ea98b38) :  CRITICAL (storage:60) - Exception reading file /config/Library/Application Support/Plex Media Server/Metadata/Movies/e/ca3ad0980077dfbd4f2024364d2a14b8b73ce2d.bundle/Contents/_combined/Info.xml (most recent call last):
2023-04-23 21:17:15,612 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
2023-04-23 21:17:15,747 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
2023-04-23 21:17:37,760 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F1008636%3Flang%3Des&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_0560888d770c7b4e6b335347444122f5f09fb001
2023-04-23 21:17:37,761 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-04-23 21:17:38,090 (7ff41ea98b38) :  CRITICAL (storage:60) - Exception reading file /config/Library/Application Support/Plex Media Server/Metadata/Movies/e/ca3ad0980077dfbd4f2024364d2a14b8b73ce2d.bundle/Contents/_combined/Info.xml (most recent call last):
2023-04-23 21:17:38,091 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
2023-04-23 21:17:38,213 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
2023-04-23 21:18:52,579 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/notify/serverUpdated?host=127.0.0.1
2023-04-23 21:18:52,581 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/notify/serverUpdated
2023-04-23 21:18:52,581 (7ff41ea98b38) :  DEBUG (peerservice:386) - Handling server update notification (127.0.0.1)
2023-04-23 21:18:52,581 (7ff41ea98b38) :  DEBUG (peerservice:189) - Updating servers (True/False True/True/True)
2023-04-23 21:18:52,582 (7ff41ea98b38) :  DEBUG (peerservice:164) - Fetching the current list of servers
2023-04-23 21:18:52,583 (7ff41ea98b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/servers'
2023-04-23 21:18:57,677 (7ff41ea06b38) :  DEBUG (runtime:717) - Handling request GET /system/notify/serverUpdated?host=127.0.0.1
2023-04-23 21:18:57,678 (7ff41ea06b38) :  DEBUG (runtime:814) - Found route matching /system/notify/serverUpdated
2023-04-23 21:18:57,678 (7ff41ea06b38) :  DEBUG (peerservice:386) - Handling server update notification (127.0.0.1)
2023-04-23 21:18:57,679 (7ff41ea06b38) :  DEBUG (peerservice:189) - Updating servers (True/False True/True/True)
2023-04-23 21:18:57,679 (7ff41ea06b38) :  DEBUG (peerservice:164) - Fetching the current list of servers
2023-04-23 21:18:57,679 (7ff41ea06b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/servers'
2023-04-23 21:19:12,688 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/System.bundle/Contents/Code/peerservice.py", line 390, in handle_notify
    self.update_servers(required_attribs=attrs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/System.bundle/Contents/Code/peerservice.py", line 195, in update_servers
    servers_el = self.get_servers_el()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/System.bundle/Contents/Code/peerservice.py", line 165, in get_servers_el
    return XML.ElementFromURL('http://127.0.0.1:32400/servers', cacheTime = 0)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 344, in ElementFromURL
    method=method,
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/networkkit.py", line 67, in _http_request
    req = self._core.networking.http_request(url, *args, **kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 346, in http_request
    return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 118, in __init__
    self.load()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-a787c5a8e/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 158, in load
    f = self._opener.open(req, timeout=self._timeout)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 429, in open
    response = self._open(req, data)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 447, in _open
    '_open', req)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 407, in _call_chain
    result = func(*args)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 1228, in http_open
    return self.do_open(httplib.HTTPConnection, req)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 1201, in do_open
    r = h.getresponse(buffering=True)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/httplib.py", line 1148, in getresponse
    response.begin()
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/httplib.py", line 448, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/httplib.py", line 404, in _read_status
    line = self.fp.readline(_MAXLINE + 1)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/socket.py", line 480, in readline
    data = self._sock.recv(self._rbufsize)
timeout: timed out
2023-04-23 21:19:12,689 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 3325 bytes
2023-04-23 21:19:17,778 (7ff41ea06b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
    method=method,
    self.load()
    '_open', req)
    response.begin()
timeout: timed out
2023-04-23 21:19:17,780 (7ff41ea06b38) :  DEBUG (runtime:924) - Response: [500] 3325 bytes
2023-04-23 21:19:17,782 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/notify/serverUpdated?host=172.19.0.2
2023-04-23 21:19:17,783 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/notify/serverUpdated
2023-04-23 21:19:17,783 (7ff41ea98b38) :  DEBUG (peerservice:386) - Handling server update notification (172.19.0.2)
2023-04-23 21:19:17,783 (7ff41ea98b38) :  DEBUG (peerservice:189) - Updating servers (True/False True/True/True)
2023-04-23 21:19:17,783 (7ff41ea98b38) :  DEBUG (peerservice:164) - Fetching the current list of servers
2023-04-23 21:19:17,784 (7ff41ea98b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/servers'
2023-04-23 21:19:37,883 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
    method=method,
    self.load()
    '_open', req)
    response.begin()
timeout: timed out
2023-04-23 21:19:37,885 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 3325 bytes
2023-04-23 21:20:31,211 (7ff41ea98b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F1008636%3Flang%3Des&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_0560888d770c7b4e6b335347444122f5f09fb001
2023-04-23 21:20:31,215 (7ff41ea98b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-04-23 21:20:31,217 (7ff41ea98b38) :  CRITICAL (storage:60) - Exception reading file /config/Library/Application Support/Plex Media Server/Metadata/Movies/e/ca3ad0980077dfbd4f2024364d2a14b8b73ce2d.bundle/Contents/_combined/Info.xml (most recent call last):
2023-04-23 21:20:31,219 (7ff41ea98b38) :  CRITICAL (runtime:889) - Exception (most recent call last):
    result = f(**d)
2023-04-23 21:20:31,223 (7ff41ea98b38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
Thank you in advance
Up!!!
bump!
bump!
