Server crashes sometimes: libc++abi: terminating with uncaught exception of type boost::wrapexcept
Sometimes, like once a month, my Plex server crashes. Docker logs then shows that the server is restarted in a loop, but crashes every time with the message
libc++abi: terminating with uncaught exception of type boost::wrapexcept<boost::uuids::entropy_error>: open /dev/urandom
docker-compose down and up fixes it temporarily. The docker logs also refer to a dump, but unfortunatly it’s not there anymore, since I restarted the container. It didn’t seem to help anyway as it only contains hardware infos and binary.
I’m running plex in docker on an ubuntu LXC on Proxmox.
Server Version#: 1.30.0.6486
Player Version#: n/a
Is this still happening on the current release ? eg latest beta 1.30.1.6497-5fc2e0894 ?
If it is please, please ensure server debug logging is enabled beforehand and restart the server and capture the server logs after a crash
If you disable crash reporting, and a minidump is created by Plex Media Server, then you can copy it out of the Crash Reports folder for the rekease and zip and include it with the zipped server logs
Hard to tell as it doesn’t crash very frequently. I’ll report back next time it happens
It just crashed again. Version is 1.30.2.6563
I had debug logs enabled. I just don’t know which of the like 150 logfiles to look at. com.plexapp.system.log seems kinda relevant and has an entry from the right time window:
2023-01-31 20:49:57,689 (7f68d60ee808) :  INFO (core:349) - Starting framework core - Version: 2.6.3, Build: 3d4dc0c (Tue Jan 10 17:42:31 UTC 2023)
2023-01-31 20:49:57,689 (7f68d60ee808) :  DEBUG (core:361) - Using the elevated policy
2023-01-31 20:49:57,689 (7f68d60ee808) :  DEBUG (core:365) - Extending whitelist: ['cgi', 'tempfile']
2023-01-31 20:49:57,689 (7f68d60ee808) :  DEBUG (core:450) - Starting runtime component.
2023-01-31 20:49:57,690 (7f68d60ee808) :  DEBUG (core:450) - Starting caching component.
2023-01-31 20:49:57,691 (7f68d60ee808) :  DEBUG (core:450) - Starting data component.
2023-01-31 20:49:57,691 (7f68d60ee808) :  DEBUG (core:450) - Starting networking component.
2023-01-31 20:49:57,691 (7f68d60ee808) :  DEBUG (networking:261) - Loaded HTTP cookies
2023-01-31 20:49:57,694 (7f68d60ee808) :  DEBUG (networking:428) - Setting the default network timeout to 20.0
2023-01-31 20:49:57,695 (7f68d60ee808) :  DEBUG (core:450) - Starting localization component.
2023-01-31 20:49:57,695 (7f68d60ee808) :  INFO (localization:409) - Setting the default locale to en-us
2023-01-31 20:49:57,695 (7f68d60ee808) :  WARNING (data:179) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting property name enclosed in double quotes: line 26 column 1 (char 1078)
2023-01-31 20:49:57,697 (7f68d60ee808) :  DEBUG (localization:427) - Loaded en strings
2023-01-31 20:49:57,697 (7f68d60ee808) :  DEBUG (core:450) - Starting messaging component.
2023-01-31 20:49:57,697 (7f68d60ee808) :  DEBUG (core:450) - Starting debugging component.
2023-01-31 20:49:57,697 (7f68d60ee808) :  DEBUG (core:450) - Starting services component.
2023-01-31 20:49:57,697 (7f68d60ee808) :  DEBUG (core:450) - Starting myplex component.
2023-01-31 20:49:57,698 (7f68d60ee808) :  DEBUG (core:450) - Starting notifications component.
2023-01-31 20:49:57,797 (7f68d60ee808) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.system in namespace 'metadata'
2023-01-31 20:49:57,806 (7f68d2d6cb38) :  DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2023-01-31 20:49:57,806 (7f68d60ee808) :  DEBUG (runtime:1117) - Created a thread named 'load_all_services'
2023-01-31 20:49:57,807 (7f68d2d6cb38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2023-01-31 20:49:57,809 (7f68d2d6cb38) :  ERROR (networking:196) - Error opening URL 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2023-01-31 20:49:57,809 (7f68d2d6cb38) :  ERROR (services:272) - Unable to load services from system. Loading from the current bundle only.
2023-01-31 20:49:57,810 (7f68d2d6cb38) :  DEBUG (services:362) - Loaded services
2023-01-31 20:49:57,812 (7f68d2d49b38) :  DEBUG (services:438) - No shared code to load
2023-01-31 20:49:57,812 (7f68d60ee808) :  DEBUG (runtime:1117) - Created a thread named 'get_server_info'
2023-01-31 20:49:57,812 (7f68d60ee808) :  DEBUG (core:150) - Finished starting framework core
2023-01-31 20:49:57,812 (7f68d60ee808) :  DEBUG (core:560) - Loading plug-in code
2023-01-31 20:49:57,825 (7f68d60ee808) :  DEBUG (core:566) - Finished loading plug-in code
2023-01-31 20:49:57,825 (7f68d60ee808) :  DEBUG (runtime:640) - Adding a prefix handler for 'System' ('/system')
2023-01-31 20:49:57,826 (7f68d2d26b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400'
2023-01-31 20:49:57,827 (7f68d2d26b38) :  ERROR (networking:196) - Error opening URL 'http://127.0.0.1:32400'
2023-01-31 20:49:57,827 (7f68d2d26b38) :  WARNING (core:541) - Unable to retrieve the machine identifier or server version.
2023-01-31 20:49:58,379 (7f68d60ee808) :  INFO (__init__:35) - Starting System 3d4dc0c (Tue Jan 10 17:42:31 UTC 2023)
2023-01-31 20:49:58,379 (7f68d60ee808) :  DEBUG (runtime:640) - Adding a prefix handler for 'Player' ('/player')
2023-01-31 20:49:58,387 (7f68d60ee808) :  INFO (datakit:93) - Loaded the dictionary file
2023-01-31 20:49:58,387 (7f68d60ee808) :  DEBUG (agentservice:52) - Starting the agent service
2023-01-31 20:49:58,482 (7f68d60ee808) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.system in namespace 'metadata'
2023-01-31 20:49:58,488 (7f68d60ee808) :  DEBUG (bundleservice:65) - Starting the bundle service
2023-01-31 20:49:58,488 (7f68d60ee808) :  DEBUG (runtime:1117) - Created a thread named 'start'
2023-01-31 20:49:58,488 (7f68d60ee808) :  DEBUG (playerservice:12) - Starting the player service
2023-01-31 20:49:58,488 (7f68d60ee808) :  DEBUG (flagservice:13) - Starting the media flag service
2023-01-31 20:49:58,489 (7f68d60ee808) :  DEBUG (runtime:1117) - Created a thread named 'start'
2023-01-31 20:49:58,489 (7f68d60ee808) :  DEBUG (peerservice:141) - Starting the peer service
2023-01-31 20:49:58,490 (7f68d2b7eb38) :  DEBUG (runtime:1117) - Created a thread named 'ensure_agent_info_exists_inner'
2023-01-31 20:49:58,490 (7f68d60ee808) :  DEBUG (runtime:1117) - Created a thread named 'refresh_servers'
2023-01-31 20:49:58,491 (7f68d2b38b38) :  DEBUG (peerservice:164) - Fetching the current list of servers
2023-01-31 20:49:58,491 (7f68d2b38b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/servers'
2023-01-31 20:49:58,492 (7f68d2b38b38) :  ERROR (networking:196) - Error opening URL 'http://127.0.0.1:32400/servers'
2023-01-31 20:49:58,494 (7f68d60ee808) :  DEBUG (runtime:1150) - Scheduled a timed thread named 'refresh_servers'
2023-01-31 20:49:58,494 (7f68d60ee808) :  DEBUG (streamservice:18) - Starting the stream service
2023-01-31 20:49:58,494 (7f68d60ee808) :  CRITICAL (runtime:709) - Private handlers are no longer supported; couldn't register <bound method StreamService.token_handler of <streamservice.StreamService object at 0x7f68d2913a90>>
2023-01-31 20:49:58,494 (7f68d2b38b38) :  CRITICAL (runtime:1128) - Exception in thread named 'refresh_servers' (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1126, in _start_thread
    f(*args, **kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/System.bundle/Contents/Code/peerservice.py", line 169, in refresh_servers
    servers_el = self.get_servers_el()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/System.bundle/Contents/Code/peerservice.py", line 165, in get_servers_el
    return XML.ElementFromURL('http://127.0.0.1:32400/servers', cacheTime = 0)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 344, in ElementFromURL
    method=method,
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/networkkit.py", line 67, in _http_request
    req = self._core.networking.http_request(url, *args, **kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 346, in http_request
    return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 118, in __init__
    self.load()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 158, in load
    f = self._opener.open(req, timeout=self._timeout)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 435, in open
    response = meth(req, response)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 548, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 473, in error
    return self._call_chain(*args)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 407, in _call_chain
    result = func(*args)
  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 556, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 503: Service Unavailable
2023-01-31 20:50:03,757 (7f68d2b7eb38) :  INFO (datakit:131) - Saved the dictionary file
2023-01-31 20:50:06,640 (7f68d2a89b38) :  ERROR (networking:196) - Error opening URL 'http://resources-cdn.plexapp.com/hashes.json'
2023-01-31 20:50:06,640 (7f68d2a89b38) :  CRITICAL (runtime:1299) - Exception getting hosted resource hashes (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1291, in get_resource_hashes
    json = self._core.networking.http_request("http://resources-cdn.plexapp.com/hashes.json", timeout=5).content
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 242, in content
    return self.__str__()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 220, in __str__
    self.load()
HTTPError: HTTP Error 404: Not Found
2023-01-31 20:50:06,640 (7f68d2a89b38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:06,641 (7f68d2b38b38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:06,641 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [404] NoneType, 0 bytes
2023-01-31 20:50:06,641 (7f68d2b38b38) :  DEBUG (runtime:924) - Response: [404] NoneType, 0 bytes
2023-01-31 20:50:06,652 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:06,653 (7f68d2b7eb38) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2023-01-31 20:50:06,654 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:06,671 (7f68d2b3db38) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:06,679 (7f68d2b3db38) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2023-01-31 20:50:06,680 (7f68d2b3db38) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:06,694 (7f68d2b3db38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:06,694 (7f68d2b3db38) :  DEBUG (runtime:924) - Response: [200] str, 59966 bytes
2023-01-31 20:50:06,702 (7f68d2b7eb38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:06,702 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 59966 bytes
2023-01-31 20:50:12,372 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/messaging/clear_events/com.plexapp.agents.imdb
2023-01-31 20:50:12,374 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/messaging/clear_events/com.plexapp.agents.imdb
2023-01-31 20:50:12,375 (7f68d2b7eb38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:12,375 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 0 bytes
2023-01-31 20:50:12,458 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.system/resourceHashes
2023-01-31 20:50:12,459 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.system/resourceHashes
2023-01-31 20:50:12,459 (7f68d2b7eb38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:12,460 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [404] NoneType, 0 bytes
2023-01-31 20:50:12,488 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:12,489 (7f68d2b7eb38) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2023-01-31 20:50:12,495 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2023-01-31 20:50:12,510 (7f68d2b7eb38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:12,510 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 59966 bytes
2023-01-31 20:50:13,037 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.system/messaging/function/[...]
2023-01-31 20:50:13,038 (7f68d2b7eb38) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2023-01-31 20:50:13,038 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.system/messaging/function/[...]
2023-01-31 20:50:13,040 (7f68d2b7eb38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:50:13,040 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 16 bytes
2023-01-31 20:50:18,046 (7f68d2b5bb38) :  INFO (datakit:131) - Saved the dictionary file
2023-01-31 20:50:34,151 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F83580%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_174b70be8ccef179c7d2211d5f62be98cfc1d8f8
2023-01-31 20:50:34,151 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,151 (7f68d2b7eb38) :  DEBUG (accessor:68) - Creating a new read-only model access point for provider com.plexapp.agents.themoviedb in namespace 'metadata'
2023-01-31 20:50:34,175 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_174b70be8ccef179c7d2211d5f62be98cfc1d8f8 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,186 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 123303 bytes
2023-01-31 20:50:34,251 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F282454%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_fadc9036d1163746435c4ac57586aa7f5d53af4d
2023-01-31 20:50:34,266 (7f68d2b43b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F546985%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_359c795ecc3107b19a7d81dc69e225bc654d75f0
2023-01-31 20:50:34,266 (7f68d2b43b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,269 (7f68d2b43b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_359c795ecc3107b19a7d81dc69e225bc654d75f0 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,275 (7f68d2b43b38) :  DEBUG (runtime:924) - Response: [200] str, 345482 bytes
2023-01-31 20:50:34,267 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,290 (7f68d2b43b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F123487%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_d36f85fad906ee21d69c81861fee1f57e7a687fc
2023-01-31 20:50:34,290 (7f68d2b43b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,295 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_fadc9036d1163746435c4ac57586aa7f5d53af4d (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,300 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F360349%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_60a457ee0c9c2c7526f2e57e7d1b0bd10c253c8a
2023-01-31 20:50:34,300 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,301 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 364406 bytes
2023-01-31 20:50:34,302 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_60a457ee0c9c2c7526f2e57e7d1b0bd10c253c8a (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,301 (7f68d2b43b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_d36f85fad906ee21d69c81861fee1f57e7a687fc (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,303 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 64656 bytes
2023-01-31 20:50:34,304 (7f68d2b43b38) :  DEBUG (runtime:924) - Response: [200] str, 30347 bytes
2023-01-31 20:50:34,360 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F368692%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_8af8d00d4e49eaecb481f05f526a7115a63e35e1
2023-01-31 20:50:34,361 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,362 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_8af8d00d4e49eaecb481f05f526a7115a63e35e1 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,363 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 190661 bytes
2023-01-31 20:50:34,365 (7f68d2b43b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F108517%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_074df23281292deb6b6d03b3f0b114ee859b33b3
2023-01-31 20:50:34,366 (7f68d2b43b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,367 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F326791%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_b3b1103716886f663fd61840864825e8309f5625
2023-01-31 20:50:34,368 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,368 (7f68d2b43b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_074df23281292deb6b6d03b3f0b114ee859b33b3 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,369 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F29147%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_152e62ed59700eb60b48911ad2010c2577381969
2023-01-31 20:50:34,369 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,371 (7f68d2b43b38) :  DEBUG (runtime:924) - Response: [200] str, 632928 bytes
2023-01-31 20:50:34,372 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_b3b1103716886f663fd61840864825e8309f5625 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,373 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_152e62ed59700eb60b48911ad2010c2577381969 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,374 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 263227 bytes
2023-01-31 20:50:34,375 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 415064 bytes
2023-01-31 20:50:34,532 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Enone%3A%2F%2F368118%3Flang%3Dxn&mediaType=9&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Elocalmedia_0b372feecc42c6de2af3bd730768bb2756f84623
2023-01-31 20:50:34,534 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,534 (7f68d2b7eb38) :  DEBUG (accessor:68) - Creating a new read-only model access point for provider com.plexapp.agents.none in namespace 'metadata'
2023-01-31 20:50:34,553 (7f68d2b7eb38) :  CRITICAL (storage:60) - Exception reading file /config/Library/Application Support/Plex Media Server/Metadata/Albums/4/159a5545a048e7d392675dc8f85086c6cd394b3.bundle/Contents/_combined/Info.xml (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/storage.py", line 55, in load
    f = open(filename, mode)
IOError: [Errno 2] No such file or directory: '/config/Library/Application Support/Plex Media Server/Metadata/Albums/4/159a5545a048e7d392675dc8f85086c6cd394b3.bundle/Contents/_combined/Info.xml'
2023-01-31 20:50:34,554 (7f68d2b7eb38) :  CRITICAL (runtime:889) - Exception (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 843, in handle_request
    result = f(**d)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/System.bundle/Contents/Code/agentservice.py", line 1082, in media_get
    data = HTTP.Request(media_url, cacheTime=0).content
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 300, in ElementFromString
    check_size(string, max_size)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-3d4dc0cce/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 22, in check_size
    if len(data) > max_size:
TypeError: object of type 'NoneType' has no len()
2023-01-31 20:50:34,577 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [500] 1037 bytes
2023-01-31 20:50:34,648 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F75774%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_5bb78c9c6205736fc2d8641e3a3b8a5bb5f2c6c7
2023-01-31 20:50:34,670 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,674 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_5bb78c9c6205736fc2d8641e3a3b8a5bb5f2c6c7 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,675 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 237467 bytes
2023-01-31 20:50:34,683 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F104647%2F1%3Flang%3Dde&mediaType=3&url=metadata%3A%2F%2Fseasons%2F1%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_b4219e8305611c701283b2f2f72c59552837e089
2023-01-31 20:50:34,683 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,685 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F112860%2F1%3Flang%3Dde&mediaType=3&url=metadata%3A%2F%2Fseasons%2F1%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_6317a5e18c14ee8bb186a955c05c85e871c52399
2023-01-31 20:50:34,685 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,687 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://seasons/1/posters/com.plexapp.agents.themoviedb_b4219e8305611c701283b2f2f72c59552837e089 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,689 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 514814 bytes
2023-01-31 20:50:34,691 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://seasons/1/posters/com.plexapp.agents.themoviedb_6317a5e18c14ee8bb186a955c05c85e871c52399 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,692 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 71740 bytes
2023-01-31 20:50:34,754 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F87083%2F3%3Flang%3Dde&mediaType=3&url=metadata%3A%2F%2Fseasons%2F3%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_7dae65bfe7ad20dc0e82679d01eb42cf3d3d032c
2023-01-31 20:50:34,755 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:34,765 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://seasons/3/posters/com.plexapp.agents.themoviedb_7dae65bfe7ad20dc0e82679d01eb42cf3d3d032c (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:34,766 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 35093 bytes
2023-01-31 20:50:35,024 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F20864%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_8e913c20086a157db9588cfeafedb24faa055f7d
2023-01-31 20:50:35,031 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,032 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F134996%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_231306f5ff45eaaf73e2046105ee6219db999583
2023-01-31 20:50:35,037 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,037 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_8e913c20086a157db9588cfeafedb24faa055f7d (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,038 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_231306f5ff45eaaf73e2046105ee6219db999583 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,039 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 223212 bytes
2023-01-31 20:50:35,039 (7f68d2545b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F193613%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_1ed137e2522696eda1b25487ce6664b5503310d9
2023-01-31 20:50:35,040 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 110325 bytes
2023-01-31 20:50:35,040 (7f68d2545b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,044 (7f68d2545b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_1ed137e2522696eda1b25487ce6664b5503310d9 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,046 (7f68d2545b38) :  DEBUG (runtime:924) - Response: [200] str, 312844 bytes
2023-01-31 20:50:35,055 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F51502%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_f847836b382679055dab030891ad03c1a9fe4280
2023-01-31 20:50:35,056 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,059 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_f847836b382679055dab030891ad03c1a9fe4280 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,061 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 42783 bytes
2023-01-31 20:50:35,083 (7f68d2b7eb38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F165236%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_cf6c38b267366b2ea13efe29e486005869dcded0
2023-01-31 20:50:35,084 (7f68d2b7eb38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,086 (7f68d2b7eb38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_cf6c38b267366b2ea13efe29e486005869dcded0 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,088 (7f68d2b7eb38) :  DEBUG (runtime:924) - Response: [200] str, 236923 bytes
2023-01-31 20:50:35,099 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Eimdb%3A%2F%2Ftt1792588%3Flang%3Dde&mediaType=1&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Eimdb_f8361586fea963424e30e30a5bc99b03cca47cd6
2023-01-31 20:50:35,099 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,100 (7f68d2a89b38) :  DEBUG (accessor:68) - Creating a new read-only model access point for provider com.plexapp.agents.imdb in namespace 'metadata'
2023-01-31 20:50:35,122 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.imdb_f8361586fea963424e30e30a5bc99b03cca47cd6 (in com.plexapp.agents.imdb)
2023-01-31 20:50:35,125 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 293535 bytes
2023-01-31 20:50:35,368 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F66980%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_94dec770cc685e3f57434265738ef34010690620
2023-01-31 20:50:35,369 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,370 (7f68d2545b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethetvdb%3A%2F%2F270633%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethetvdb_091fcfa2a667edc4fa6cc3e333b498960d20b83d
2023-01-31 20:50:35,371 (7f68d2545b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,371 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_94dec770cc685e3f57434265738ef34010690620 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,371 (7f68d2545b38) :  DEBUG (accessor:68) - Creating a new read-only model access point for provider com.plexapp.agents.thetvdb in namespace 'metadata'
2023-01-31 20:50:35,375 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 45824 bytes
2023-01-31 20:50:35,376 (7f68d2545b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.thetvdb_091fcfa2a667edc4fa6cc3e333b498960d20b83d (in com.plexapp.agents.thetvdb)
2023-01-31 20:50:35,377 (7f68d2545b38) :  DEBUG (runtime:924) - Response: [200] str, 144995 bytes
2023-01-31 20:50:35,379 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F81224%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_09faa2247df9e751b5e1820cbe923b4ae37518d2
2023-01-31 20:50:35,380 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,383 (7f68d2545b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F100402%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_479b30270b4a17c19ad1c9fa6c21949fa2edb82e
2023-01-31 20:50:35,383 (7f68d2545b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,384 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_09faa2247df9e751b5e1820cbe923b4ae37518d2 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,386 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 357111 bytes
2023-01-31 20:50:35,386 (7f68d2545b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_479b30270b4a17c19ad1c9fa6c21949fa2edb82e (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,389 (7f68d2545b38) :  DEBUG (runtime:924) - Response: [200] str, 610033 bytes
2023-01-31 20:50:35,403 (7f68d247db38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F45%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_7865516eb97714a33f4316ea9e91419b1190b816
2023-01-31 20:50:35,404 (7f68d247db38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,405 (7f68d2a89b38) :  DEBUG (runtime:717) - Handling request GET /system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F46112%3Flang%3Dde&mediaType=2&url=metadata%3A%2F%2Fposters%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_7236ddb88139cb0febe22e665492accbc85e4f62
2023-01-31 20:50:35,405 (7f68d2a89b38) :  DEBUG (runtime:814) - Found route matching /system/agents/media/get
2023-01-31 20:50:35,406 (7f68d2a89b38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_7236ddb88139cb0febe22e665492accbc85e4f62 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,407 (7f68d2a89b38) :  DEBUG (runtime:924) - Response: [200] str, 104741 bytes
2023-01-31 20:50:35,408 (7f68d247db38) :  DEBUG (agentservice:1082) - Returning stored data for metadata://posters/com.plexapp.agents.themoviedb_7865516eb97714a33f4316ea9e91419b1190b816 (in com.plexapp.agents.themoviedb)
2023-01-31 20:50:35,412 (7f68d247db38) :  DEBUG (runtime:924) - Response: [200] str, 1351301 bytes
2023-01-31 20:51:58,492 (7f68d2b15b38) :  DEBUG (runtime:1156) - Starting timed thread named 'refresh_servers'
2023-01-31 20:51:58,492 (7f68d2b15b38) :  DEBUG (peerservice:164) - Fetching the current list of servers
2023-01-31 20:51:58,492 (7f68d2b15b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/servers'
2023-01-31 20:51:58,494 (7f68d2b15b38) :  DEBUG (peerservice:171) - Refreshing local server
2023-01-31 20:51:58,494 (7f68d2b15b38) :  DEBUG (peerservice:189) - Updating servers (True/False True/True/True)
2023-01-31 20:51:58,494 (7f68d2b15b38) :  DEBUG (peerservice:198) - Found 1 servers
2023-01-31 20:51:58,494 (7f68d2b15b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400'
2023-01-31 20:51:58,496 (7f68d2b15b38) :  DEBUG (core:521) - Attribute 'machineIdentifier' set to 'fe2ce5b33bf56c8f4a67e9af447399a82e78b639'
2023-01-31 20:51:58,496 (7f68d2b15b38) :  DEBUG (peerservice:230) - Creating new server maeries Plex (fe2ce5b33bf56c8f4a67e9af447399a82e78b639)
2023-01-31 20:51:58,497 (7f68d2b15b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/sections'
2023-01-31 20:51:58,500 (7f68d2b15b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/channels/all'
2023-01-31 20:51:58,502 (7f68d2545b38) :  DEBUG (peerservice:176) - Background-refreshing remote servers
2023-01-31 20:51:58,502 (7f68d2b15b38) :  DEBUG (runtime:1117) - Created a thread named 'background_refresh'
2023-01-31 20:51:58,502 (7f68d2545b38) :  DEBUG (peerservice:189) - Updating servers (True/False True/True/True)
2023-01-31 20:51:58,502 (7f68d2545b38) :  DEBUG (peerservice:198) - Found 1 servers
2023-01-31 20:51:58,502 (7f68d2545b38) :  DEBUG (peerservice:233) - Updating existing server maeries Plex (fe2ce5b33bf56c8f4a67e9af447399a82e78b639)
2023-01-31 20:51:58,503 (7f68d2545b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/sections'
2023-01-31 20:51:58,506 (7f68d2545b38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/channels/all'
2023-01-31 20:53:40,618 (7f68d2b17b38) :  DEBUG (runtime:717) - Handling request GET /system/:/prefs
2023-01-31 20:53:40,619 (7f68d2b17b38) :  DEBUG (runtime:814) - Found route matching /system/:/prefs
2023-01-31 20:53:40,623 (7f68d2b17b38) :  DEBUG (preferences:258) - Loaded preferences from DefaultPrefs.json
2023-01-31 20:53:40,624 (7f68d2b17b38) :  DEBUG (preferences:178) - Loaded the user preferences for com.plexapp.system
2023-01-31 20:53:40,625 (7f68d2b17b38) :  DEBUG (runtime:88) - Sending packed state data (99 bytes)
2023-01-31 20:53:40,625 (7f68d2b17b38) :  DEBUG (runtime:924) - Response: [200] MediaContainer, 418 bytes
Best is to download the logs zip through the Plex Web settings page for Troubleshooting - after restarting the server
The main log files are the Plex Media Server.log and Plex Media Server.x.log files
and also for the dump id’s - the Plex Crash Uploader.log and Plex Crash Uploader.x.log - but it is always best to upload the logs zip file
If the crash was detected and intercepted by the crash reporting process, there would be a dmp file to look for
