It's my understanding that the only way to maintain chapters within an MKV file is to play the file through a dedicated PC connected to the TV and running PLEX Home Theater.
Am I understanding correctly that PLEX Home Theater can be installed on a Raspberry Pi that will then have all of the PHT functionality of a traditional desktop computer?
(My PLEX Media Server is a Synology DS214play.)
If it works on PHT on a PC or Mac then yes it will. Rasplex is a direct port of PHT running on top of OpenELEC, with Pi specific enhancements. Latest version is 0.4.1 which is basically PHT 1.2.2.
I’m having quite some troubles with a MKV that has chapters on the latest RasPlex/OpenPHT right now. I can’t fast forward, skip more than 30 secs at once or resume the file in the middle. Works fine in Web or iOS. Any known bugs currently?
I even tried that, but upon selecting a chapter in the iOS remote the movie would just start from the beginning on RasPlex. Absolutely any attempt to scroll/seek that file would result in failure, either complete stop/hangup or just no reaction at all.
Weird. That’s what I do for chapters and it works fine.
Did you find a fix at all?
