Does the Apple TV's remote Siri voice control allow you to search Plex libraries?
Server Version#: 4.50.1
Player Version#: 7.11 (1)
AppleTV v4
Hi all,
On my Bravia remote’s voice control and Plex app, I can search my various Plex libraries by voice.
Haven’t been able to get the same functionality from my Apple TV’s siri functions. Some on reddit claim to be able to do so, but when I follow their instructions, I have no luck.
Is there a way to do it?
Thx!
No. Plex does not work with Siri.
Yes it does. I figured it out.
Can you explain what you did? This is not something Plex has added support for.
It works in Plex like it does for Netflix or YouTube. The only reason I was having an issue was because I had turned off “Dictation” in the Apple TV settings by accident.
How would a “Plex Employee” not know this?
Are you just dictating into the Plex app’s search bar? That’s just dictation, which is a built-in feature. It’s not actually using Siri to search for anything.
