Server Version#: 1.20.1.3252
Player Version#: 8.6.0.20351
Currently I have a Plex Server and a Sony Bravia XG9505 with the latest firmware version.
I have Plex Player on Sony TV but I can’t for the life of me get TrueHD Audio to my ATMOS soundbar which is setup with earc and a 48Gbps hdmi cable.
If I grab one of my truehd A/V files and place it on a USB and then plug it into the Tv for playback I get ATMOS no problem so it’s a problem with the Plex app. Turning on Network logging shows the following line:
09-12 14:52:42.884 i: [MediaDecisionEngine] Unable to direct play; TrueHD audio is not supported by the device
This happens if I have Audio Passthrough enabled/disabled on both Plex and the Sony TV but in either case it should work because both the Sony TV and the Soundbar have support for ATMOS.
Anyone any idea what I can do to get this working?
Thanks for that detail about 4K playback it’s actually something I’m looking at because of the transcoding that’s going on.
But with regards to the issue with ATMOS audio, the INFO you sent across states that the receiver (TV) needs to support TrueHD Audio which it does as shown by my tests.
We may never get an official explanation, however it seems apparent to me that e-arc is a function of the hdmi protocol, hdmi includes encryption and copy protection in the hardware.
Apps simply do not, and likely never will have access to the hardware level necessary to pass over e-arc.
Besides the fact there are no legitimate sources of hd audio other than directly from Blu-ray, which already works over hdmi.
