Server Version#: 1.24.1.4931
Player Version#: Roku, Fire TV: Any TV that does not support Dolby Vision
I am seeing some crazy tone mapping issues on TV’s that do not support Dolby Vision, is there a setting that needs to be enabled for this? Colors are Green and Pink
This is enabled: “Enable HDR tone mapping” under transcoding
Here is a snipit from the movie file:
Media
- Duration 2:12:06
- Bitrate 18695 kbps
- Width 3840
- Height 2160
- Aspect Ratio 1.78
- Video Resolution 4K
- Container MP4
- Video Frame Rate 24p
- Web Optimized Yes
- Has 64bit Offsets true
- Video Profile main 10
Part
Duration 2:12:06
File test.mp4
Size 17.25 GB
Container MP4
Indexes sd
Web Optimized Yes
Codec HEVC
Bitrate 17927 kbps
D O V I B L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 5
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Subsampling 4:2:0
Codec ID dvhe
Coded Height 2160
Coded Width 3840
Color Range pc
Frame Rate 23.97599983215332 fps
Height 2160
Level 5.0
Profile main 10
Ref Frames 1
Stream Identifier 1
Width 3840
Display Title 4K (HEVC Main 10)
Extended Display Title 4K (HEVC Main 10)
Codec EAC3
Channels 6
Bitrate 768 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Stream Identifier 2
Display Title English (EAC3 5.1)
Extended Display Title English (EAC3 5.1)
Codec MOV_TEXT
Language English
Language Tag en
Stream Identifier 3
Display Title English (MOV_TEXT)
Extended Display Title English (MOV_TEXT)
Codec MOV_TEXT
Language English
Language Tag en
Stream Identifier 4
Codec MOV_TEXT
Language Spanish
Language Tag es
Stream Identifier 5
Display Title Spanish (MOV_TEXT)
Extended Display Title Spanish (MOV_TEXT)
