Double adding and Rename issues
Server Version#:1.22.1.4275
Issue add movies and they randomly show up twice in recently added movies. Checked server only has 1.
When I add movies and Tv shows even after the rename they mostly still show up with full download tag.
Tried multiple changes to fix this scanning threw the other people with the issue nothing seems to be curing the issues I’m having.
Ok thank you im gonna change some things here tonite rework some folder and I’ll give you a update soon thank you
Ok the double adding is fixed,
but i seem to still have the issue with tv shows and some movie names not showing true name after I use filebot to change to correct. Most still show the internet name of the file. “Episode 12
·RARBG - SEAL.Team.S04E12.WEBRip.x264-ION10”
This is after the file gets ran threw filebot. Plenty of movies are the same way.
Any thoughts??
