Downloaded files no longer showing
Hey so all my downloaded content has vanished from the App. Still shows that the external storage on the android tablet is in use, but nothing is showing up. Also downloaded content will still play if i search it in my library (and it is playing the offline downloaded content) but again nothing showing in the Downloads section
Which version number of app are you using?
Version number is
10.26.0.2578
You have completely ruined the new app - and specifically the download functionality.
In the old app you could select a TV Show and select to download the net ‘x’ unwatched episodes. Then when you watched on it would delete the watched one and download a new one. As you selected the TV show it would also download over multiple series.
With the new app - you can only download at a series level. Once you watch it it still remains in the downloads. You have to go into downloads and delete it all manually.
Same with deleting old content that has been migrated. You’ve moved everything to single entries, so each TV episode has to be deleted manually - you can’t just delete a whole show!
It was working so well - and last app update you migrated to ‘downloads’ and broke it. The same has happened again with downloads - broken again.
Typical - no reply…
