I have Prefer downloaded content enabled but the only place that it plays the downloaded copy of the files is when it’s initiated from the Downloads menu option. Everywhere else it streams from the server.
Can follow the same steps as above to get it to happen or you can make sure an item is downloaded, go to a library, start playing, check the Playback Info and see that it is not Direct Play (On this device).
Otherwise feature seems to be working well. Love no more transcoding to download.
That issue was for the iOS app and was fixed. I’m not aware of this issue appearing on Android. Please reproduce and provide me the Android log. I’m not able to reproduce myself. For me, the Downloaded version is played.
Edit:
So looking more into the logs, it looks like it is playing the local file, but when I look at the Playback Info it tells me it’s DirectPlay (MY_SERVER) not Direct Play (On this device). Guess it’s just a visual bug with that menu then.
Ok, it looks like there 2 small bugs. The app is still going through the logic of asking your server for the file but then overrides that with the local copy. The display is likely from the initial request so it thinks it is streaming from the server.
I’ll investigate this some more and see about getting it fixed. Thanks for the report.
It’s possible that it’s a display bug. Did you check the server dashboard to see what that showed?
When I initiate play from the Home dashboard (or library)
Shows in the sever dashboard
Lists the streams but not if it’s Direct Playing or Streaming (Tautulli says it’s Direct Play)
No bandwidth indication (Tautulli shows 0 kbps)
Doesn’t show my sidecar subtitle (srt) although the dashboard and playback info says it is
From the Downloads section
Doesn’t show in server dashboard at all
Shows sidecar subtitles perfectly
