DreamPlex - ein Plex Client für Enigma2
No that should be it. Sounds like the myplex acc of the dreamplex cant access the server. But you should also be able to access the server using an IP under server settings right? I would try that next
I must have had some connection problems with the Server, it now works without changing anything.
But thank you for helping me :)
Changelog for 2.1.0-beta33
- implemented filter in server menu (press number keys)
- small tweaks and bugfixes
Downloads
http://sourceforge.net/projects/dreamplex/files/Beta/deb/enigma2-plugin-extensions-dreamplex_2.1.0-beta33_all.deb/download
http://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta33_all.ipk/download
Don:
opkg install enigma2-plugin-extensions-dreamplex_2.1.0-beta33_all.ipk
Not downgrading package DreamPlex on root from 2.1.0-beta.31 to 2.1.0-beta33.
version nr wrong ?
Thanks a lot Don, I will try it this weekend.
Don:
version nr wrong ?
I have the same message....
Same here
just use
 --force-downgrade via ssh or telnet
hope this helps
greets
Tnx Dondavici,
now seems to work.
opkg install --force-downgrade enigma2-plugin-ex
Downgrading DreamPlex on root from 2.1.0-beta.31 to 2.1.0-beta33...
Starting installation of DreamPlex ...
Deleting presets ...
Deleting cache files ...
Removing obsolete file /usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/Makefile.am.
Configuring DreamPlex.
# Have fun using DreamPlex #
root@vusolo2:/var/volatile/tmp
Hey guys just put dream plex on my solo2. Can I sign into myplex account directly through the plug in or do I have to connect it to my computer through the plex media server?
You don't need a server althoug if noone share the content with you... what the hell are you going to play?  :blink:
I’ve got a friend who shares his content with me but I don’t no how to login on dream plex lol
Changelog for 2.1.0-beta37
-small tweak for multiple ips on plex server
- increased timeout once more again to have enough time to spin ups hdd
- fixed progress/resume function
- added new picons -> big thx to maggy
Downloads
http://sourceforge.net/projects/dreamplex/files/Beta/deb/enigma2-plugin-extensions-dreamplex_2.1.0-beta37_all.deb/download
http://sourceforge.net/projects/dreamplex/files/Beta/ipk/enigma2-plugin-extensions-dreamplex_2.1.0-beta37_all.ipk/download
Thanks DonDavici, always waiting for your improvements. :)
Hello
I'm using my Vu + Dreamplex SOLO2 and truth that is great.
But I have a little problem, as I can change the default audio movies?
I always opens them in English and I have to change it to Spanish by hand until you leave and re-enter the program that audio is not always defaults.
Thanks DonDavici by this program  :)
@Moha85, I have a lot of dual movies, both spanish and english and it works perfect. Usually the main reason is you have not the "default" flag on the movie audio track. Use a program like mkvtoolnix to inspect the audio track and set it as default. You have to remux the movie again though.
How to...
  • Select the spanish audio track (and only the audio track)
  • Select language "spanish" o "castillian"
  • And finally set it as "default" audio track
  • Now you can "remux" the movie with "Start muxing".
The new movie will have as default language the spanish track and it will play always as default....
Thanks for the reply
The problem is that I have very many movies on my server and NAS clear to remux all films is very tedious, since I have to move to PC, remux and re-sent to the NAS. UFFF :o
But I think I have now found the solution in the menu audio VU SOLO2 there is an option that reminds you of the selected track to the application or something (not sure) I restarted the GUI and it seems that now opens me all movies in Spanish  :)
Better then.  :rolleyes:
Hello,
I am using for some time with great pleasure Dreamplex without actually getting into the settings ..
I would like to optimize my Dreamplex experience, primarily using the most optimal mode for the best picture and sound for movies visonner.
  • streamed
  • Local Direct
  • transcoded
Which one?
So I have a DM800HD is (original) with last image OpenPLi 4.0
with over Dreamplex stable version 2.0.3
I use a Panasonic Plasma full HD 50 ', and a Denon amplifier (DTS only, not HD, not HDMI)
And my server is my PC (using the latest version of Plex Media Server installed) directly connected to the dreambox by ethernet CAT6a , via the internet box (no wifi, no CPL)
Thank's in advance
