DreamPlex - ein Plex Client für Enigma2
i see :-) the problem is that dreamplex does not know your machine identifieres. just go to server settings and open once every entry you have. just hit save in each of them. this will save the machine identifiers. this should solve it :-)
My crashlog:
<?xml version="1.0" encoding="utf-8"?>
		Mon Oct 20 22:20:20 2014
		Oct  7 2014
		dondavici@gmail.com
		PLi-HD/skin.xml
		2014-10-06
		(no branch)
		3b5c543
		3.0.0
		dm800se
		root=/dev/mtdblock3 rootfstype=jffs2 rw console=ttyS0,115200 quiet bmem=116M@140M
		NIM Socket 0:
			<![CDATA[
openpli 4 %h
InfobarChannelSelection keyUp action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions keyLeft action -> ChannelSelectBaseActions showFavourites action -> OkCancelActions ok action -> OkCancelActions ok statfs failed! playing 1:0:19:57D:E:46:E080000:0:0:0: [eDVBCAService] free slot 0 demux 0 for service 1:0:19:B18:24:56:310000:0:0:0: [eDVBCAService] free service 1:0:19:B18:24:56:310000:0:0:0: decoder state: play, vpid=-1, apid=-1 DEMUX_STOP - pcr - ok DEMUX_STOP - video - ok VIDEO_STOP - ok AUDIO_STOP - ok DEMUX_STOP - audio - ok AUDIO_CONTINUE - ok start release channel timer getResolvedKey config.usage.remote_fallback failed !! (Typo??) statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! new service started! trying to download cuts! download failed, no cuesheet interface RemovePopup, id = ZapError [eDVBLocalTimerHandler] remove channel 0x19be928 [eEPGCache] remove channel 0x19be928 allocate channel.. 000e:0046 (0)tune RotorCmd ffffffff, lastRotorCmd ffffffff prepare_sat System 1 Freq 10934000 Pol 0 SR 25000000 INV 2 FEC 3 orbpos 3592 system 1 modulation 2 pilot 2, rolloff 1 tuning to 1184 mhz OURSTATE: tuning allocate Channel: res 0 [eDVBCIInterfaces] addPMTHandler 1:0:19:57D:E:46:E080000:0:0:0: allocate demux [SEC] set static current limiting statfs failed! set sequence pos 3 set sequence pos 7 [SEC] invalidate current switch params [SEC] sendDiseqc: e01038f6(?) [SEC] sleep 50ms set sequence pos 3 set sequence pos 3 [SEC] update current switch params [SEC] startTuneTimeout 5000 [SEC] setFrontend 1 setting frontend 0 (0)fe event: status 0, inversion off, m_tuning 1 [SEC] sleep 500ms (0)fe event: status 1, inversion off, m_tuning 2 (0)fe event: status 1f, inversion off, m_tuning 3 OURSTATE: ok [eDVBLocalTimerHandler] channel 0x19be928 running [eEPGCache] channel 0x19be928 running [EPGC] next update in 2 sec stop release channel timer ok ... now we start!! eventNewProgramInfo 0 0 have 1 video stream(s) (0417), and 1 audio stream(s) (0be7), and the pcr pid is 0417, and the text pid is 179a allocate demux decoder state: play, vpid=1047, apid=3047 DMX_SET_PES_FILTER(0x417) - pcr - ok DEMUX_START - pcr - ok DMX_SET_PES_FILTER(0xbe7) - audio - ok DEMUX_START - audio - ok AUDIO_SET_BYPASS(0) - ok AUDIO_PAUSE - ok AUDIO_PLAY - ok Video Device: /dev/dvb/adapter0/video0 demux device: /dev/dvb/adapter0/demux0 VIDEO_SET_STREAMTYPE 1 - ok DMX_SET_PES_FILTER(0x417) - video - ok DEMUX_START - video - ok VIDEO_FREEZE - ok VIDEO_PLAY - ok DMX_SET_PES_FILTER(0x179a) - ttx - ok DEMUX_START - ttx - ok VIDEO_SLOWMOTION(0) - ok VIDEO_FAST_FORWARD(0) - ok VIDEO_CONTINUE - ok AUDIO_CONTINUE - ok disable teletext subtitles page ffffffffffffffff (und) statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! [eDVBCAService] new service 1:0:19:57D:E:46:E080000:0:0:0: [eDVBCAService] add demux 0 to slot 0 service 1:0:19:57D:E:46:E080000:0:0:0: RemovePopup, id = ZapError PATready use pmtpid 004f for service_id 057d [eDVBLocalTimerHandler] diff is -2 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] update RTC [eDVBLocalTimerHandler] time update to 19:04:58 [eDVBLocalTimerHandler] m_time_difference is -2 [eDVBLocalTimerHandler] set Linux Time [SEC] set dynamic current limiting eventNewProgramInfo 0 0 have 1 video stream(s) (0417), and 1 audio stream(s) (0be7), and the pcr pid is 0417, and the text pid is 179a decoder state: play, vpid=1047, apid=3047 [eDVBCIInterfaces] gotPMT sdt update done! [Dish] tuning failed [EPGC] start caching events(1413824700) [EPGC] abort non avail schedule reading [EPGC] abort non avail schedule other reading [EPGC] abort non avail netmed schedule reading [EPGC] abort non avail netmed schedule other reading [EPGC] abort non avail FreeSat schedule_other reading [EPGC] abort non avail viasat reading [EPGC] nownext finished(1413824707) [EPGC] stop caching events(1413824707) [EPGC] next update in 60 min [eDVBLocalTimerHandler] diff is 0 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] not changed [eDVBLocalTimerHandler] diff is 0 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] not changed [EPGC] start caching events(1413828307) [EPGC] abort non avail schedule reading [EPGC] abort non avail schedule other reading [EPGC] abort non avail netmed schedule reading [EPGC] abort non avail netmed schedule other reading [EPGC] abort non avail FreeSat schedule_other reading [EPGC] abort non avail viasat reading [EPGC] nownext finished(1413828314) [EPGC] stop caching events(1413828314) [EPGC] next update in 60 min 192.168.43.1 - - [20/Oct/2014 20:16:22] "GET /resources HTTP/1.1" 200 - 192.168.43.1 - - [20/Oct/2014 20:16:22] "GET /resources HTTP/1.1" 200 - [eDVBLocalTimerHandler] diff is -1 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] difference between linux time and RTC time is < 60 sec... so the transponder time looks ok [eDVBLocalTimerHandler] time update to 20:34:58 [eDVBLocalTimerHandler] m_time_difference is -1 [eDVBLocalTimerHandler] set Linux Time action -> InfobarChannelSelection keyUp action -> OkCancelActions ok statfs failed! playing 1:0:19:1A91:43:46:E080000:0:0:0: [eDVBCAService] free slot 0 demux 0 for service 1:0:19:57D:E:46:E080000:0:0:0: [eDVBCAService] free service 1:0:19:57D:E:46:E080000:0:0:0: decoder state: play, vpid=-1, apid=-1 DEMUX_STOP - pcr - ok DEMUX_STOP - video - ok VIDEO_STOP - ok AUDIO_STOP - ok DEMUX_STOP - audio - ok AUDIO_CONTINUE - ok DEMUX_STOP - ttx - ok start release channel timer getResolvedKey config.usage.remote_fallback failed !! (Typo??) statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! new service started! trying to download cuts! download failed, no cuesheet interface RemovePopup, id = ZapError [eDVBLocalTimerHandler] remove channel 0x19be928 [eEPGCache] remove channel 0x19be928 allocate channel.. 0043:0046 (0)tune RotorCmd ffffffff, lastRotorCmd ffffffff prepare_sat System 1 Freq 10778000 Pol 1 SR 25000000 INV 2 FEC 3 orbpos 3592 system 1 modulation 2 pilot 2, rolloff 1 tuning to 1028 mhz OURSTATE: tuning allocate Channel: res 0 [eDVBCIInterfaces] addPMTHandler 1:0:19:1A91:43:46:E080000:0:0:0: allocate demux [SEC] set static current limiting statfs failed! set sequence pos 3 [SEC] setVoltage 1 [SEC] sleep 20ms set sequence pos 3 [SEC] invalidate current switch params [SEC] sendDiseqc: e01038f4(?) [SEC] sleep 50ms set sequence pos 3 set sequence pos 3 [SEC] update current switch params [SEC] startTuneTimeout 5000 [SEC] setFrontend 1 setting frontend 0 (0)fe event: status 0, inversion off, m_tuning 1 [SEC] sleep 500ms (0)fe event: status 1, inversion off, m_tuning 2 (0)fe event: status 1f, inversion off, m_tuning 3 OURSTATE: ok [eDVBLocalTimerHandler] channel 0x19be928 running [eEPGCache] channel 0x19be928 running stop release channel timer ok ... now we start!! [EPGC] next update in 2 sec RemovePopup, id = ZapError PATready use pmtpid 0132 for service_id 1a91 [eDVBLocalTimerHandler] diff is 1 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] update RTC [eDVBLocalTimerHandler] time update to 21:00:37 [eDVBLocalTimerHandler] m_time_difference is 1 [eDVBLocalTimerHandler] set Linux Time eventNewProgramInfo 0 0 have 1 video stream(s) (04e7), and 1 audio stream(s) (0cb7), and the pcr pid is 04e7, and the text pid is 18a6 allocate demux decoder state: play, vpid=1255, apid=3255 DMX_SET_PES_FILTER(0x4e7) - pcr - ok DEMUX_START - pcr - ok DMX_SET_PES_FILTER(0xcb7) - audio - ok DEMUX_START - audio - ok AUDIO_SET_BYPASS(1) - ok AUDIO_PAUSE - ok AUDIO_PLAY - ok Video Device: /dev/dvb/adapter0/video0 demux device: /dev/dvb/adapter0/demux0 VIDEO_SET_STREAMTYPE 1 - ok DMX_SET_PES_FILTER(0x4e7) - video - ok DEMUX_START - video - ok VIDEO_FREEZE - ok VIDEO_PLAY - ok DMX_SET_PES_FILTER(0x18a6) - ttx - ok DEMUX_START - ttx - ok VIDEO_SLOWMOTION(0) - ok VIDEO_FAST_FORWARD(0) - ok VIDEO_CONTINUE - ok AUDIO_CONTINUE - ok disable teletext subtitles page ffffffffffffffff (und) statfs failed! not pauseable. statfs failed! not pauseable. statfs failed! [eDVBCAService] new service 1:0:19:1A91:43:46:E080000:0:0:0: [eDVBCAService] add demux 0 to slot 0 service 1:0:19:1A91:43:46:E080000:0:0:0: [eDVBCIInterfaces] gotPMT [SEC] set dynamic current limiting [Dish] tuning failed sdt update done! [EPGC] start caching events(1413831639) [EPGC] abort non avail schedule reading [EPGC] abort non avail schedule other reading [EPGC] abort non avail netmed schedule reading [EPGC] abort non avail netmed schedule other reading [EPGC] abort non avail FreeSat schedule_other reading [EPGC] abort non avail viasat reading [EPGC] nownext finished(1413831646) [EPGC] stop caching events(1413831646) [EPGC] next update in 60 min [eDVBLocalTimerHandler] diff is 0 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] not changed 192.168.43.1 - - [20/Oct/2014 21:41:41] "GET /resources HTTP/1.1" 200 - [eDVBLocalTimerHandler] diff is -1 [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time [eDVBLocalTimerHandler] difference between linux time and RTC time is < 60 sec... so the transponder time looks ok [eDVBLocalTimerHandler] time update to 22:00:37 [eDVBLocalTimerHandler] m_time_difference is -1 [eDVBLocalTimerHandler] set Linux Time [EPGC] start caching events(1413835245) [EPGC] abort non avail schedule reading [EPGC] abort non avail schedule other reading [EPGC] abort non avail netmed schedule reading [EPGC] abort non avail netmed schedule other reading [EPGC] abort non avail FreeSat schedule_other reading [EPGC] abort non avail viasat reading [EPGC] nownext finished(1413835252) [EPGC] stop caching events(1413835252) [EPGC] next update in 60 min 192.168.43.1 - - [20/Oct/2014 22:05:57] "GET /resources HTTP/1.1" 200 - action -> InfobarMenuActions mainMenu loading mainmenu XML... TimerEdit TimerEditList PluginBrowser PluginBrowser action -> MenuActions menu action -> InfobarMenuActions mainMenu loading mainmenu XML... TimerEdit TimerEditList PluginBrowser PluginBrowser action -> OkCancelActions ok okbuttonClick <enigma.eVideoWidget; proxy of > action -> DP_MainMenuActions right action -> DP_MainMenuActions right action -> DP_MainMenuActions ok action -> DP_MainMenuActions ok action -> SetupActions right action -> SetupActions right action -> SetupActions 1 unknown action SetupActions/1! typo in keymap? action -> SetupActions 1 unknown action SetupActions/1! typo in keymap? action -> SetupActions 1 unknown action SetupActions/1! typo in keymap? action -> SetupActions save unknown action SetupActions/save! typo in keymap? action -> ColorActions green action -> DP_MainMenuActions green unknown action DP_MainMenuActions/green! typo in keymap? action -> DP_MainMenuActions right action -> DP_MainMenuActions ok action -> ShortcutActions red action -> MsgBoxActions ok action -> ShortcutActions red action -> MsgBoxActions ok action -> ShortcutActions blue Waiting for results ERROR reading PES (fd=59) - Value too large for defined data type poll: unhandled POLLERR/HUP/NVAL for fd 59(8) action -> WizardActions ok action -> DPS_ServerConfig right action -> DPS_ServerConfig right action -> DPS_ServerConfig left action -> ColorActions green action -> WizardActions back action -> DP_MainMenuActions right action -> DP_MainMenuActions right action -> DP_MainMenuActions ok <enigma.eVideoWidget; proxy of > action -> DPS_Syncer cancel action -> DP_MainMenuActions cancel action -> DP_MainMenuActions ok <enigma.eVideoWidget; proxy of > action -> DP_MainMenuActions ok Traceback (most recent call last): File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action File "/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/DP_ServerMenu.py", line 200, in okbuttonClick self.getServerData("movies") File "/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/DP_ServerMenu.py", line 393, in getServerData serverData = self.plexInstance.getAllSections(filterBy) File "/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/DP_PlexLibrary.py", line 391, in getAllSections self.saveSectionCache() File "/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/DP_PlexLibrary.py", line 1044, in saveSectionCache fd = open(self.sectionCache, "wb") IOError: [Errno 2] No such file or directory: '/hdd/dreamplex/cache/sections.cache' (PyObject_CallObject(<bound method HelpableActionMap.action of >,('DP_MainMenuActions', 'ok')) failed) getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??) getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??) getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??) ]]>
Thanks Dude, this feature is awesome :)
1 more question, for Subtitles to work do I need to enable Transcoding instead of direct stream?
yes. at the moment you have to transcode to have subtitles. only if there are embeded once it might work with streamed.
<span><a  class="" href="https://forums.plex.tv/user/227701-murre87/" title="">murre87</a></span>
you dont have a hdd mounted or at least a hdd folder. this is needed to store some files for dreamplex.
OK. Have no hdd but can fix that
Thanks again Don, this is just great. I found the Menu of Dreamplex to be a bit slow on my vuplus uno, but just choosing the movie or show on my iphone makes it much easier :)
@ murre87
Great. Now I can cast [emoji1]
I always use subtitle and then have to choose transcode in dreamplex, but sound and video is real bad with transcode enabled even with highest settings (20mbit)
what do you mean with bad. is it like bad at all because this is normal that way and every device or is it bad like why in heavons name it looks like that. could not be?
Sound and video looks like its from 1980 when transcode.
Have tried to transcode with same satteing to my android SGS3 and thts look sharp.
Direct play and Stream look and sounds sharp
What do you thing about the quality when transcoding shapetheLOLa?
mhmm interesting i transcode mysel also everything with 4mbit and this looks good as well. looks like this could be a generel problem. please provide me your setting.
what box.what image. gst-fragmented installed and last but not least a dreamplex log so that i can have a look what commands are sent to the server.
thx in advance
Dont think dm800se with openpli 4 have a log?
why not? just activate in settings direct in dreamplex. do what ever you have to do. (please note that debug slows down) - send me the log file. turn off logging again,
Im having trouble with the latest 21 beta, when pausing and continuing a show or movie gives me a green crash screen, will provide a log later
please check with latest beta 22 :-)
Dear DonDavici,
are this skins that i see in the GitHub still live or not?
  • DreamPlexSkin_Plexi
  • DreamPlexSkin_BlackDon
  • DreamPlex_showiframe
Tnx
Still the same problem !
i need the crashlog :-)
Dear DonDavici,
Tnx
sorry they are all for the old version. means up to version 1.9.8. since 2.0 they are not compatible.
		Thu Oct 23 20:47:26 2014
		Nov  5 2013
		MetrixHD/skin.xml
		2013-11-05
		vti-master
		uno
		bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
		NIM Socket 0:
		6.0.3
			<![CDATA[
version=1000201311051559
comment=vuplus
target=9
creator=VTi
url=http://www.vuplus-support.org/
catalog=http://www.vuplus-support.org
			 /etc/enigma2/ci
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
resolve: resolve ${sysconfdir}/enigma2/ci
resolve: -> /etc/enigma2/ci
[CI_Activate_Config_CI1] no config file found
[CI_Activate_Config_CI1] error parsing xml...
starting hotplug handler
Looking for embedded skin
[AutoShutDown] start....
port changed to DVI
mode changed to 1080i
default ('1080i', 'Standard')
preferedmodes ['720p', '576p', '480p', '576i', '480i', ('1080i', 'Standard')]
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
setValue 100
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
warning, skin is missing element etitle in
playing service..
main thread is non-idle! display spinner!
not pauseable.
allocate channel.. 000d:0085
opening frontend 0
[eDVBCAService] new channel 0x1879268!
(0)tune
tuning to 698000 khz, sr 6900000, fec 0, modulation 5, inversion 2
OURSTATE: tuning
[eDVBCIInterfaces] addPMTHandler 1:0:19:72:D:85:FFFF0000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] setFrontend 1
setting frontend 0
child has terminated
pipes closed
pipes closed
pipes closed
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1879268 running
[eDVBLocalTimerHandler] channel 0x1879268 running
no version filtering
0014:  70 00 00 00 00 00
mask:  fc 00 00 00 00 00
mode:  00 00 00 00 00 00
[eEPGCache] channel 0x1879268 running
0012:  4e 00 72 00 00 00
mask:  ff ff ff 00 00 00
0000:  00 00 00 00 00 00
mask:  ff 00 00 00 00 00
have 1 video stream(s) (03ff), and 1 audio stream(s) (0403), and the pcr pid is 03ff, and the text pid is 0020
allocate demux
decoder state: play, vpid=1023, apid=1027
DMX_SET_PES_FILTER(0x3ff) - pcr - ok
DMX_SET_PES_FILTER(0x403) - audio - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
DMX_SET_PES_FILTER(0x3ff) - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x20) - ttx - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
not pauseable.
[AutoRes] service changed
File not exists : /tmp/.sock.hbbtv.cmd
No found pipe!!
pipes closed
0.0.0.0
10.0.1.
169.254
nameservers: [[208, 122, 23, 22], [208, 122, 23, 23]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': False, 'netmask': [255, 255, 255, 0], 'gateway': [10, 0, 1, 1], 'address': [10, 0, 1, 9]}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [10, 0, 1, 9], 'up': True, 'dns-nameservers': '	dns-nameservers 208.122.23.22 208.122.23.23
', 'mac': '00:1d:ec:05:11:67', 'dhcp': False, 'netmask': [255, 255, 255, 0], 'gateway': [10, 0, 1, 1]}}
AT plugin not found
ER plugin not found
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
[OpenWebif] loading external plugins...
[OpenWebif] no plugins to load
[OpenWebif] started on 80
[OpenWebif] started on 443
[MetrixWeather] lookup for ID 640161
+- 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
use pmtpid 0063 for service_id 0072
0063:  02 00 72 00 00 00
doing version filtering
0000:  00 00 00 19 00 00
mask:  ff 00 00 3f 00 00
mode:  00 00 00 3e 00 00
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[AutoRes] got event evFramerateChanged
[AutoRes] got event evVideoProgressiveChanged
++ 2/2 TID 4e
done!
0012:  4e 00 72 25 00 00
mask:  ff ff ff 3f 00 00
+ 1/1 TID 02
done!
have 1 video stream(s) (03ff), and 2 audio stream(s) (0402, 0403), and the pcr pid is 03ff, and the text pid is 0020
No found pipe!!
[eDVBCAService] new service 1:0:19:72:D:85:FFFF0000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:19:72:D:85:FFFF0000:0:0:0:
demux 0 mask 01 prevhash 00000000
0063:  02 00 72 39 00 00
[AutoRes] determineContent
sdt update done!
No found pipe!!
[eDVBLocalTimerHandler] dont have correction.. set Transponder Diff
[eDVBLocalTimerHandler] time update to 20:46:43
[eDVBLocalTimerHandler] m_time_difference is 1414089950
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
[EPGC] create epg.dat backup
[EPGC] 10871 events read from /hdd/epg.dat
[EPGC] create real epg.dat backup
PTS-Plugin: Erasing stranded timeshift timeshift.4zzD9J
before: 1
after: 1
setIoPrio best-effort level 7 ok
file /media/hdd//timeshift.4zzD9J.del erased
PTS-Plugin: Erasing stranded timeshift pts_livebuffer.1
before: 1
before: 1
before: 1
file /media/hdd//pts_livebuffer.1.del erased
file /media/hdd//pts_livebuffer.1.meta.del erased
file /media/hdd//pts_livebuffer.1.eit.del erased
[EPGC] start caching events(1414090006)
Start timeshift!
recording to /media/hdd/timeshift.fJRaLs
before: 1
after: 1
setIoPrio realtime level 7 ok
FILEPUSH THREAD START
[EITSave] query epg event id 8122, 1:0:19:72:D:85:FFFF0000:0:0:0:
[EITSave] found event.. store to disc
[eDVBCAService] send 79 bytes
9f 80 32 4b 03 00 72 39 00 31 01 81 08 ff ff 00 00 00 0d 00 85 82 02 01 00 84 02 00 63 09 04 18 50 f9 5c 09 04 18 35 fb 5c 09 04 18 38 fc 5c 09 04 18 31 fd 5c 09 04 09 8e fe 5c 06 00 20 00 00 1b 03 ff 00 00 06 04 02 00 00 06 04 03 00 00
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1414090013)
[EPGC] schedule finished(1414090016)
no ancillary data in audio stream... abort radiotext pes parser
10.0.1.26 - - [23/Oct/2014 20:47:01] "OPTIONS /player/timeline/poll?wait=0&commandID=0 HTTP/1.1" 200 -
10.0.1.26 - - [23/Oct/2014 20:47:01] "GET /player/timeline/poll?wait=0&commandID=0 HTTP/1.1" 200 -
[EPGC] schedule other finished(1414090023)
[EPGC] stop caching events(1414090023)
10.0.1.26 - - [23/Oct/2014 20:47:11] "OPTIONS /player/playback/playMedia?key=%2Flibrary%2Fmetadata%2F3450&offset=989000&machineIdentifier=d9d2829fb990e2cf6987b495390f3386f1c32631&address=10.0.1.3&port=32400&protocol=http&containerKey=%2FplayQueues%2F1266%3Fown%3D1%26window%3D200&commandID=1 HTTP/1.1" 200 -
10.0.1.26 - - [23/Oct/2014 20:47:11] "GET /player/playback/playMedia?key=%2Flibrary%2Fmetadata%2F3450&offset=989000&machineIdentifier=d9d2829fb990e2cf6987b495390f3386f1c32631&address=10.0.1.3&port=32400&protocol=http&containerKey=%2FplayQueues%2F1266%3Fown%3D1%26window%3D200&commandID=1 HTTP/1.1" 200 -
[OpenWebif] page '/web/powerstate?newstate=4' ok (cheetah template)
10.0.1.26 - - [23/Oct/2014 20:47:13] "OPTIONS /player/timeline/poll?wait=1&commandID=1 HTTP/1.1" 200 -
resolved to PLAY
eDVBServicePlay::unpause
[Picload] setPara max-X=195 max-Y=268 aspect_ratio=1.000000 cache=0 resize=1 bg=#002C2C39
10.0.1.26 - - [23/Oct/2014 20:47:13] "GET /player/timeline/poll?wait=1&commandID=1 HTTP/1.1" 200 -
[Picload] decode picture... /hdd/dreamplex/media/jserver_3446_poster_195x268_v2.jpg
stopService
stopping thread.
FILEPUSH THREAD STOP
thread joined 0
[Timeshift] remove ts file
before: 1
after: 1
old thread joined 0
[eDVBCAService] free slot 0 demux 0 for service 1:0:19:72:D:85:FFFF0000:0:0:0:
[eDVBCAService] free service 1:0:19:72:D:85:FFFF0000:0:0:0:
file /media/hdd/timeshift.fJRaLs.del erased
VIDEO_STOP - ok
AUDIO_STOP - ok
AUDIO_CONTINUE - ok
playing service..
eServiceMP3::construct!
eServiceMP3::playbin2
eServiceMP3::starting pipeline
getBouquet failed.. no path given!
eServiceMP3::state transition NULL -> READY
eServiceMP3::GST_STREAM_STATUS_TYPE_CREATE -> setting timeout on souphttpsrc to 10s
cannot blit 32bpp from 4bpp
eServiceMP3::state transition READY -> PAUSED
eServiceMP3::appsink properties set!
eServiceMP3::async-done - 1 video, 1 audio, 1 subtitle
eServiceMP3::audio stream=0 codec=AC-3 audio language=en
eServiceMP3::subtitle stream=0 language=en codec=(null)
getSubtitleType::unidentifiable subtitle stream!
eServiceMP3::state transition PAUSED -> PLAYING
gstTextpadHasCAPS:: signal::caps = text/x-pango-markup
getSubtitleType::subtitle probe caps type=text/x-pango-markup
pullSubtitle m_subtitleStreams[m_currentSubtitleStream].type=2
got new text subtitle @ buf_pos = 4104000000 ns (in pts=369363): 'Hey, sorry we're late
with the snacks.'
check subtitle: decoder: 352, show_pts: 4104, diff: 3752 ms
start timer
got new text subtitle @ buf_pos = 6040000000 ns (in pts=543605): 'Plus we had a little situation
at the grocery store.'
release cached channel (timer timeout)
[eDVBCAService] remove channel 0x1879268
[eDVBLocalTimerHandler] remove channel 0x1879268
[eEPGCache] remove channel 0x1879268
eServiceMP3::seekTo failed
close frontend 0
check subtitle: decoder: 992512, show_pts: 4104, diff: -988407 ms
subtitle too late... drop
check subtitle: decoder: 992512, show_pts: 6040, diff: -986471 ms
got new text subtitle @ buf_pos = 988254000000 ns (in pts=88943749): 'Come on, nate. Enough
small talk about mom.'
check subtitle: decoder: 992512, show_pts: 988263, diff: -4248 ms
got new text subtitle @ buf_pos = 990457000000 ns (in pts=89142021): 'Let's get to the problem.'
check subtitle: decoder: 992512, show_pts: 990466, diff: -2045 ms
got new text subtitle @ buf_pos = 991992000000 ns (in pts=89280172): 'Sure is a lot
about you in there.'
check subtitle: decoder: 992512, show_pts: 992001, diff: -510 ms
got new text subtitle @ buf_pos = 995261000000 ns (in pts=89574385): 'I'm his mother.
He loves me.'
check subtitle: decoder: 992544, show_pts: 995270, diff: 2726 ms
start timer
got new text subtitle @ buf_pos = 996730000000 ns (in pts=89706597): 'Ah. Oh, here it is.'
action: playpauseService
action ->  InfobarSeekActions playpauseService
resolved to PAUSE
eServiceMP3::state transition PLAYING -> PAUSED
check subtitle: decoder: 995168, show_pts: 995270, diff: 102 ms
start timer
start timer
start timer
10.0.1.26 - - [23/Oct/2014 20:47:24] "OPTIONS /player/timeline/poll?wait=1&commandID=1 HTTP/1.1" 200 -
10.0.1.26 - - [23/Oct/2014 20:47:24] "GET /player/timeline/poll?wait=1&commandID=1 HTTP/1.1" 200 -
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
start timer
resolved to PLAY
  File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 1061, in action
    return HelpableActionMap.action(self, contexts, action)
    res = self.actions[action]()
  File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 1209, in playpauseService
    self.unPauseService()
  File "/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/DP_Player.py", line 604, in unPauseService
    self.transcoderHeartbeat.stop()
AttributeError: 'DP_Player' object has no attribute 'transcoderHeartbeat'
(PyObject_CallObject(<bound method InfoBarSeekActionMap.action of >,('InfobarSeekActions', 'playpauseService')) failed)
