DreamPlex - ein Plex Client für Enigma2
can you post a screenshot here please. thx
 It seems to be a under/overscan-problem with my tv. Got it right with the other TV.
It Doesnt shows with PLI-HD skin but i shows with Matrix HD. It always shows in Dreamplex nomather what skin i have.
Just wondering how to actually change skins? Selecting skins in settings on my vu+solo2 changes nothing. Is the old plexi skin available with the new version - hope so it looked great on the pre 2.0 versions!
I'd like to have more skins too, but i think at the moment, no other skins are available.
I hope i'm wrong.
hi,
currently there is my main skin and this one ..
http://www.vuplus-support.org/wbb3/index.php?page=Thread&threadID=69568
maybe there will be more :-)
hi,
Well to know,
Tnx.
Can you please tell us if there will be more?
Nice Skin! A little bit slow to respond to remote commands but looks great - thanks for that!
On another subject music currently plays with a blank screen is there any chance of getting album art or even a choice of muted tv to play on screen along with the music?
Hi Don !
nice Work, I have DreamPlex running on a VU+ Solo2 and I'm struggling a little with the subtitles.
I'm connecting to a dreamplex Server, and subtitles are working great when connecting through the Web UI or the Ipad.
So I activate the Transcode in dreamplex server menu
I tried with universal transcoder and without
reencodequality 1,5 Mbps 480mbps and 1920x1080 8mbps
When I'm starting a TV Show, Im selecting the subtile with text before
Hitting blue buton I only have (Default / Direct Local / Streamed)
If I'm letting Defalut, I assume it is with Transcoding, and Universal Transcoder Not Selected, I have a crash (Green Screen)
If Universal transcoder the playback is starting but the quality is poor, I have the smae issue on the Ipad (universal encoder porr quality)
What shall I do to make the "other" encoder running ?
When I removed dremplex my DM800se got stuck in bootloop and greenscreen.
<?xml version="1.0" encoding="utf-8"?>
		Thu Jan  1 01:02:12 1970
		Aug 11 2014
		forum at www.openpli.org
		Default Skin
		2014-08-10
		(no branch)
		2db31ea
		3.0.0
		dm800se
		root=/dev/mtdblock3 rootfstype=jffs2 rw console=ttyS0,115200 quiet bmem=116M@140M
		NIM Socket 0:
			<![CDATA[
openpli 4 %h
<![CDATA[
  • (1) Background File Eraser
  • (5) Tuxtxt
  • (8) graphics acceleration manager
  • (9) GFBDC
    16384k video mem
  • double buffering available!
    9184kB available for acceleration surfaces.
    resolution: 1280 x 720 x 32 (stride: 5120)
  • (9) gLCDDC
    found OLED display!
    lcd buffer 0x99fdb0 12288 bytes, stride 192
    LCD resolution: 96 x 64 x 16 (stride: 192)
  • (9) Font Render Class
    [FONT] initializing lib…
    [FONT] loading fonts…
    [FONT] Intializing font cache, using max. 4MB…
  • (10) gRC
    RC thread created successfully
  • (15) eWindowStyleManager
  • (20) DVB-CI UI
  • (20) UHF Modulator
    couldnt open /dev/rfmod0!!!
  • (20) RC Input layer
  • (20) misc options
  • (20) AVSwitch Driver
    couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
  • (21) input device driver
    Input device “dreambox front panel” is a remotecontrol
    Input device “dreambox remote control (native)” is a remotecontrol
    Input device “dreambox advanced remote control (native)” is a remotecontrol
    Input device “dreambox ir keyboard” is a keyboard
    Input device “dreambox ir mouse” is a mouse
    Found 5 input devices.
  • (22) Hdmi CEC driver
    eHdmiCEC: detected physical address change: 1000 --> 1200
    eHdmiCEC: send message 84 12 00 03
  • (30) eActionMap
  • (35) CI Slots
    scanning for common interfaces…
    cannot open /proc/stb/tsmux/input0
    cannot open /proc/stb/tsmux/input1
    done, found 0 common interface slots
  • (35) CA handler
  • (40) eServiceCenter
    settings instance.
  • (41) eServiceFactoryDVD
  • (41) eServiceFactoryHDMI
  • (41) eServiceFactoryM2TS
  • (41) eServiceFactoryMP3
  • (41) eServiceFactoryFS
  • (41) eServiceFactoryDVB
  • (41) Encoders
  • (41) Stream server
    reached rl 70
    ---- opening lame channel db
    reading services (version 4)
    loaded 158 channels/transponders and 2206 services
    scanning for frontends…
    opening frontend 0
    close frontend 0
    found 1 adapter, 1 frontends(1 sim) and 5 demux, boxtype 3
    RTC not ready… wait for transponder time
    [EPGC] Initialized EPGCache (wait for setCacheFile call now)
    Loading spinners…
    [ePNG] couldn’t open /usr/share/enigma2/skin_default/spinner/wait8.png
    found 7 spinner!
setIoPrio best-effort level 3 ok
couldn’t open /proc/stb/misc/12V_output
Scanning hardware info
Detected: dm800se
[Harddisk] enumerating block devices…
main thread is non-idle! display spinner!
Reading satellites.xml
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr BCM4505, need rotorworkaround No, enabled Yes, DVB-S2 Yes
slot: 0 configmode: simple
diseqcmode: diseqc_a_b
sec config completed
loading bouquet… /etc/enigma2/bouquets.tv
loading bouquet… /etc/enigma2/userbouquet.ollan.tv
194 entries in Bouquet userbouquet.ollan.tv
loading bouquet… /etc/enigma2/userbouquet.viasat.tv
85 entries in Bouquet userbouquet.viasat.tv
loading bouquet… /etc/enigma2/userbouquet.Canaldigital.tv
62 entries in Bouquet userbouquet.Canaldigital.tv
loading bouquet… /etc/enigma2/userbouquet.kalgarden.tv
194 entries in Bouquet userbouquet.kalgarden.tv
loading bouquet… /etc/enigma2/userbouquet.viaradio.tv
19 entries in Bouquet userbouquet.viaradio.tv
loading bouquet… /etc/enigma2/userbouquet.dbe05.tv
54 entries in Bouquet userbouquet.dbe05.tv
loading bouquet… /etc/enigma2/userbouquet.dbe04.tv
19 entries in Bouquet userbouquet.dbe04.tv
loading bouquet… /etc/enigma2/userbouquet.dbe03.tv
9 entries in Bouquet userbouquet.dbe03.tv
loading bouquet… /etc/enigma2/userbouquet.dbe02.tv
46 entries in Bouquet userbouquet.dbe02.tv
loading bouquet… /etc/enigma2/userbouquet.dbe01.tv
148 entries in Bouquet userbouquet.dbe01.tv
loading bouquet… /etc/enigma2/userbouquet.dbe00.tv
35 entries in Bouquet userbouquet.dbe00.tv
loading bouquet… /etc/enigma2/userbouquet.favourites.tv
0 entries in Bouquet userbouquet.favourites.tv
loading bouquet… /etc/enigma2/userbouquet.LastScanned.tv
641 entries in Bouquet userbouquet.LastScanned.tv
13 entries in Bouquet bouquets.tv
loading bouquet… /etc/enigma2/bouquets.radio
loading bouquet… /etc/enigma2/userbouquet.dbe00.radio
19 entries in Bouquet userbouquet.dbe00.radio
loading bouquet… /etc/enigma2/userbouquet.favourites.radio
0 entries in Bouquet userbouquet.favourites.radio
2 entries in Bouquet bouquets.radio
Renumbering…
[FONT] adding font /usr/share/fonts/nmsbd.ttf…OK (Regular)
[FONT] adding font /usr/share/fonts/andale.ttf…OK (Fixed)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf…OK (Console)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf…OK (Replacement)
[FONT] adding font /usr/share/fonts/lcd.ttf…OK (LCD)
[FONT] adding font /usr/share/fonts/nmsbd.ttf…OK (Arial)
[FONT] adding font /usr/share/enigma2/MetrixHD/fonts/digi.ttf…OK (DIGI)
[FONT] adding font /usr/share/enigma2/MetrixHD/fonts/OpenSans-Regular.ttf…OK (Regular)
[FONT] adding font /usr/share/enigma2/MetrixHD/fonts/OpenSans-Regular.ttf…OK (RegularLight)
[FONT] adding font /usr/share/enigma2/MetrixHD/fonts/setrixHD.ttf…OK (SetrixHD)
[FONT] adding font /usr/share/enigma2/MetrixHD/fonts/meteocons.ttf…OK (Meteo)
[FONT] adding font /usr/share/fonts/valis_enigma.ttf…OK (Subs)
[FONT] adding font /usr/share/fonts/nmsbd.ttf…OK (FdLcD)
Unknown device type: dreambox front panel
Activating keymap: Default (US)
[ePopen] command: loadkmap < /usr/share/keymaps/default.kmap
Activating language English
–> setting scaler_sharpness to: 0000000D
[ePopen] command: ip -o addr show dev eth0
[ePopen] command: ip -o addr show dev wlan0
setLCDBrightness 25
setLCDBrightness 127
[SoftcamSetup] fallback to default translation for Softcam setup
[SoftcamSetup] fallback to default translation for Lets you configure your softcams
Plugin Extensions/WebInterface failed to load: No module named plugin
Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
[AutoBackup] fallback to default translation for Automatic settings backup
[AudioSync] fallback to default translation for Audio Sync Setup
[AudioSync] fallback to default translation for Setup for the Audio Sync Plugin
[AudioSync] fallback to default translation for sets the Audio Delay (LipSync)
getModeList for port DVI-PC
getModeList for port YPbPr
getModeList for port Scart
hotplug on dvi
-> setting aspect, policy, policy2, wss 16:9 panscan letterbox auto
setMode - port: DVI mode: 720p rate: multi
[NetworkBrowser] fallback to default translation for NetworkBrowser
[NetworkBrowser] fallback to default translation for Search for network shares
[NetworkBrowser] fallback to default translation for MountManager
[NetworkBrowser] fallback to default translation for Manage network shares
[NetworkBrowser] fallback to default translation for Mount again
[NetworkBrowser] fallback to default translation for Attempt to mount shares again
EXCEPTION IN PYTHON STARTUP CODE:
Traceback (most recent call last):
File “/usr/lib/enigma2/python/mytest.py”, line 590, in
runScreenTest()
File “/usr/lib/enigma2/python/mytest.py”, line 438, in runScreenTest
plugins.readPluginList(resolveFilename(SCOPE_PLUGINS))
File “/usr/lib/enigma2/python/Components/PluginComponent.py”, line 104, in readPluginList
File “/usr/lib/enigma2/python/Components/PluginComponent.py”, line 29, in addPlugin
File “/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/plugin.py”, line 54, in Autostart
File “/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/init.py”, line 434, in prepareEnvironment
File “/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/init.py”, line 266, in registerSkinParamsInstance
File “/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/common.py”, line 739, in getXmlContent
IOError: [Errno 2] No such file or directory: ‘/usr/lib/enigma2/python/Plugins/Extensions/DreamPlex/skins/default/params’
(exit code 5)
This add-on is so much appreciated, I simply LOVE IT.
Thx, DonDavici.
Anyone knows why Subtitles and Audio language is not present when I use transcode from my.plex.tv option.
Is it possible to make that option, to have language and subtitles available when transcoding .mkv files? I know it's possible when using PHT on windows and mac.
Is it possible to make the dreambox act like a chromecast
I Choose a movie from my android-plexclient and cast it tho the dreambox?
Thx, DonDavici.
hi this is already possible.
in the screen where you can start a movie or show there is the information that you can press text or audio button to change subtitle or language before playback. :-)
this is also already possible. for now only as beta. if you want to test just switch to updatetype beta and install the latest beta. right now it is 2.1.0-beta17. in settings enable remoteplayer :-) thats it :-)
seems that you didnt remove everything. remove again or delete manually.  /usr/lib/enigma2/python/Plugins/Extensions/ here delete DreamPlex folder :-)
Thx, again DonDavici for quick respond. :)
I guess I have to be in Dreamplex for this to work? Im not on latest beta since today but get a green crash screen when going into a sub menu of TVshows or Movies now
Same here only greenscrren when enter subfolders TV and movies. Did a fresh OPEN PLI 4 install and dreamplex beta 17 but only greenscreen.
Would have been awsome if i dindnt hade to have dreamplex opened to cast to it..
no need to have dreamplex open at all. there is a http deamon running that start dreamplex automatically if needed.
in case of gs i would need the crash log to find out what is going on. always use latest beta.
It doesn’t start any video on my side nothing happens
Gesendet von meinem iPhone mit Tapatalk
do you see your box as remote player? did you start the service in settings of dreamplex and did you restart your box after this?
please provide dreamplex or crahslogs. without them i am not able to help :slight_smile:
Yea, I activated it in the settings and restarted, can even choose it within Plex on my ipad or iphone. Just nothing happens afterwards. Ill put together a log one sec
The only entries in the debug log I get are the following :
Product: Uno
 (10.0.1.9)Version: 2.1.0-beta20
Protocol: plex
Protocol-Version: 1
Protocol-Capabilities: playback, navigation
Device-Class: stb
01:00:45.0697787 >>> C <<< HttpDeamon::startDeamon -> <<<<<<<<<<
01:00:48.0918985 >>> S <<< Plugins.Extensions.DreamPlex.DPH_RemoteListener -> >>>>>>>>>>
01:00:49.0138489 >>> D <<< Plugins.Extensions.DreamPlex.DPH_RemoteListener -> Serving HTTP on 0.0.0.0 port 32400
20:19:41.0581338 >>> S <<< RemoteHandler::do_GET -> >>>>>>>>>>
20:19:41.0583582 >>> D <<< RemoteHandler::do_GET -> Serving GET request…
20:19:41.0588329 >>> S <<< RemoteHandler::answer_request -> >>>>>>>>>>
20:19:41.0591222 >>> S <<< RemoteHandler::address_string -> >>>>>>>>>>
20:19:41.0593167 >>> C <<< RemoteHandler::address_string -> <<<<<<<<<<
20:19:41.0599515 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:19:41.0604024 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:19:41.0611084 >>> D <<< RemoteHandler::answer_request -> request path is: [player/playback/playMedia]
20:19:41.0721775 >>> S <<< RemoteHandler::getParams -> >>>>>>>>>>
20:19:41.0724019 >>> C <<< RemoteHandler::getParams -> <<<<<<<<<<
20:19:41.0730486 >>> D <<< RemoteHandler::answer_request -> target machineIdentifier: d9d2829fb990e2cf6987b495390f3386f1c32631
20:19:41.0733837 >>> D <<< RemoteHandler::answer_request -> current machineIdentifier:
20:19:41.0736277 >>> D <<< RemoteHandler::answer_request -> no match …
20:19:41.0738606 >>> C <<< RemoteHandler::answer_request -> <<<<<<<<<<
20:19:41.0740887 >>> C <<< RemoteHandler::do_GET -> <<<<<<<<<<
20:20:09.0307645 >>> S <<< RemoteHandler::do_GET -> >>>>>>>>>>
20:20:09.0310123 >>> D <<< RemoteHandler::do_GET -> Serving GET request…
20:20:09.0312229 >>> S <<< RemoteHandler::answer_request -> >>>>>>>>>>
20:20:09.0314349 >>> S <<< RemoteHandler::address_string -> >>>>>>>>>>
20:20:09.0316339 >>> C <<< RemoteHandler::address_string -> <<<<<<<<<<
20:20:09.0320699 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:20:09.0326440 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:20:09.0329009 >>> D <<< RemoteHandler::answer_request -> request path is: [player/playback/playMedia]
20:20:09.0389820 >>> S <<< RemoteHandler::getParams -> >>>>>>>>>>
20:20:09.0391989 >>> C <<< RemoteHandler::getParams -> <<<<<<<<<<
20:20:09.0396634 >>> D <<< RemoteHandler::answer_request -> target machineIdentifier: d9d2829fb990e2cf6987b495390f3386f1c32631
20:20:09.0399079 >>> D <<< RemoteHandler::answer_request -> current machineIdentifier:
20:20:09.0401308 >>> D <<< RemoteHandler::answer_request -> no match …
20:20:09.0403612 >>> C <<< RemoteHandler::answer_request -> <<<<<<<<<<
20:20:09.0405754 >>> C <<< RemoteHandler::do_GET -> <<<<<<<<<<
20:20:14.0290200 >>> S <<< RemoteHandler::do_GET -> >>>>>>>>>>
20:20:14.0292592 >>> D <<< RemoteHandler::do_GET -> Serving GET request…
20:20:14.0294826 >>> S <<< RemoteHandler::answer_request -> >>>>>>>>>>
20:20:14.0297119 >>> S <<< RemoteHandler::address_string -> >>>>>>>>>>
20:20:14.0299462 >>> C <<< RemoteHandler::address_string -> <<<<<<<<<<
20:20:14.0304103 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:20:14.0307821 >>> S <<< RemoteHandler::setAccessControlHeaders -> >>>>>>>>>>
20:20:14.0310271 >>> D <<< RemoteHandler::answer_request -> request path is: [player/playback/stop]
20:20:14.0415002 >>> S <<< RemoteHandler::address_string -> >>>>>>>>>>
20:20:14.0417317 >>> C <<< RemoteHandler::address_string -> <<<<<<<<<<
20:20:14.0422143 >>> C <<< RemoteHandler::answer_request -> <<<<<<<<<<
20:20:14.0424180 >>> C <<< RemoteHandler::do_GET -> <<<<<<<<<<
