Drobo 5N Server/PlexConnect
Nothing on the wiki or on the release post from Elan addressed if the Drobo 5N can utilize the new plexconnect for ATV.  I assume the answer is no because the software is only supported on Mac/PC...
So my question is.. is there a Drobo 5N version in the pipeline?
What OS does it run?
Plexconnect is made in Python. It runs fine on a Drobo 5N (even a Drobo FS)
dogzipp,
How do you get PC to run on a Drobo FS ? Apologies if this is a basic Q ! I don't have DroboApps installed on my FS - would I need to ?
Andy
You need to install Python in your DroboApps share. SSH helps too for debugging, and starting up the script.
You can get python from www.droboports.com
Here's a thread on the Drobo forums you can follow:
http://www.drobospace.com/forums/showthread.php?tid=96676&highlight=plexconnect
It should be fairly the same for the FS.
