Ds218+ run Plex from mobile chromecast to samsung TV problem lacking.
Hi Guy,
Please help me to check the problem.
Thanks,
Sorry Ds 218+
Jimmy,
I edited the title for you.
What type problem are you seeing?
I look you your logs and I see it playing. Yes, it is transcoding but it is transcoding fast enough (speed = 1.1 -> 1.3 which is enough )
I do see a problem with subtitles and file analysis. PMS doesn’t know what’s happening in the file
Mar 17, 2018 18:54:03.526 [0x7f0154d11700] WARN - [Chromecast] [MDE] Unable to validate videoResolution; re-analyze the media if possible
Mar 17, 2018 18:54:03.604 [0x7f0148911700] WARN - [Chromecast] [MDE] Direct play failed; multi-track audio is required
Mar 17, 2018 18:54:03.748 [0x7f0158911700] WARN - [Chromecast] [MDE] Unable to validate videoResolution; re-analyze the media if possible
Mar 17, 2018 18:54:03.945 [0x7f015ba23700] DEBUG - Created thumbnail of size 1920x1080, has pixels: 1
Mar 17, 2018 18:54:04.164 [0x7f0148bff700] WARN - [Chromecast] [MDE] Direct play failed; vobsub subtitles
Mar 17, 2018 18:54:04.190 [0x7f015bd11700] DEBUG - Completed: [192.168.1.49:51737] 200 GET /photo/:/transcode?url=%2Flibrary%2Fmetadata%2F1385%2Fart%2F1521204565%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx539-4274-8ede-70dc0e295904&width=1920&height=1080 (15 live) TLS GZIP 1541ms 237675 bytes (pipelined: 3)
Mar 17, 2018 18:54:04.282 [0x7f0158911700] WARN - [Chromecast] [MDE] Soft subtitles failed; bitmap subtitles
Mar 17, 2018 18:54:04.422 [0x7f0154d11700] INFO - [Chromecast] [MDE] Finished analysis of 1080 (mkv, h264, dca-ma, 41, high)
Mar 17, 2018 18:54:04.525 [0x7f0148bff700] INFO - [Chromecast]   canPlay: true
Mar 17, 2018 18:54:04.614 [0x7f0154d11700] INFO - [Chromecast]   canDirectPlay: false
Mar 17, 2018 18:54:04.706 [0x7f0158911700] INFO - [Chromecast]   canDirectStreamVideo: false
Mar 17, 2018 18:54:04.789 [0x7f015ba23700] INFO - [Chromecast]   canDirectStreamAudio: false
Mar 17, 2018 18:54:04.864 [0x7f0148911700] INFO - [Chromecast]   useSoftSubtitles: false
Mar 17, 2018 18:54:04.904 [0x7f0158911700] DEBUG - Request: [127.0.0.1:49034 (Loopback)] PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=0&id=0&codec=h264&type=video (16 live) Signed-in Token (jimmy7302@gmail.com)
Mar 17, 2018 18:54:04.904 [0x7f015bd11700] DEBUG - Completed: [127.0.0.1:49034] 206 PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=0&id=0&codec=h264&type=video (15 live) 0ms 227 bytes
Mar 17, 2018 18:54:04.905 [0x7f0148bff700] DEBUG - Request: [127.0.0.1:49036 (Loopback)] PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=1&id=0&codec=ac3&type=audio (16 live) Signed-in Token (jimmy7302@gmail.com)
Mar 17, 2018 18:54:04.906 [0x7f015bd11700] DEBUG - Completed: [127.0.0.1:49036] 206 PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=1&id=0&codec=ac3&type=audio (16 live) 0ms 227 bytes
Mar 17, 2018 18:54:04.907 [0x7f015ba23700] DEBUG - Request: [127.0.0.1:49038 (Loopback)] PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=2&id=0&codec=dts&type=audio (17 live) Signed-in Token (jimmy7302@gmail.com)
Mar 17, 2018 18:54:04.908 [0x7f015bd11700] DEBUG - Completed: [127.0.0.1:49038] 206 PUT /video/:/transcode/session/3itqed6dfyf0p8hltfyj9q99/7988d29d-cdff-41b0-965e-58d97df7224c/progress/stream?index=2&id=0&codec=dts&type=audio (16 live) 0ms 227 bytes
Mar 17, 2018 18:54:05.010 [0x7f0148911700] INFO - [Chromecast]   bitrate: 12252
Mar 17, 2018 18:54:05.078 [0x7f0148bff700] INFO - [Chromecast]   videoResolution: 1080
I run plex on windows 10 and got this problem. I send you the log file and video recording in rar file.
Please help me to solve this problem.
Thanks,
Jimmy,
Jimmy,
Your log files are from PMS running on Synology . How is Windows involved?
I means run plex client on windows 10 . Now I run Plex client on android box to Samsung TV.
Thanks!
I looked at the input file. You’re running AAC audio with ok video. PMS is having to make a conversion to send to the ChromeCast (remux). Because you can’t use the hardware acceleration yet, the CPU alone isn’t fast enough.
Can you hover over the movie with your mouse, click ‘Get Info’ -> ‘View XML’ and show me that info?
Here you are.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="6" librarySectionTitle="Movies vol 1" librarySectionUUID="02c9164f-5423-4c9d-842a-e2d0bf2fae9e" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1519709489">
<Video ratingKey="1367" key="/library/metadata/1367" guid="com.plexapp.agents.imdb://tt2380307?lang=en" librarySectionTitle="Movies vol 1" librarySectionID="6" librarySectionKey="/library/sections/6" studio="Pixar Animation Studios" type="movie" title="Coco" contentRating="PG" summary="Despite his family’s baffling generations-old ban on music, Miguel dreams of becoming an accomplished musician like his idol, Ernesto de la Cruz. Desperate to prove his talent, Miguel finds himself in the stunning and colorful Land of the Dead following a mysterious chain of events. Along the way, he meets charming trickster Hector, and together, they set off on an extraordinary journey to unlock the real story behind Miguel's family history." rating="9.7" audienceRating="9.5" viewOffset="2113000" lastViewedAt="1521336763" year="2017" tagline="The celebration of a lifetime" thumb="/library/metadata/1367/thumb/1520867943" art="/library/metadata/1367/art/1520867943" duration="6302006" originallyAvailableAt="2017-10-27" addedAt="1520867825" updatedAt="1520867943" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" hasPremiumExtras="1" hasPremiumPrimaryExtra="1" ratingImage="rottentomatoes://image.rating.ripe">
<Media videoResolution="1080" id="3710" duration="6302006" bitrate="15454" width="1920" height="804" aspectRatio="2.35" audioChannels="8" audioCodec="dca-ma" videoCodec="h264" container="mkv" videoFrameRate="24p" audioProfile="ma" videoProfile="high">
<Part accessible="1" exists="1" id="3710" key="/library/parts/3710/1520000835/file.mkv" duration="6302006" file="/volume1/Movies/Coco.2017.1080p.BluRay.DTS-HD.MA.7.1.x264_NongZEZA@CtHts/Coco.2017.1080p.BluRay.DTS-HD.MA.7.1.x264_NongZEZA@CtHts.mkv" size="12173780744" audioProfile="ma" container="mkv" videoProfile="high">
<Stream id="8817" streamType="1" default="1" codec="h264" index="0" bitrate="13278" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" frameRate="23.976" hasScalingMatrix="0" height="804" level="41" profile="high" refFrames="4" scanType="progressive" title="Coco.2017.1080p.BluRay.DTS-HD.MA.7.1.x264_NongZEZA@CtHts" width="1920"/>
<Stream id="8818" streamType="2" default="1" forced="1" codec="ac3" index="1" channels="6" bitrate="640" language="ไทย" languageCode="tha" audioChannelLayout="5.1(side)" samplingRate="48000" title="Thai BluRay Master"/>
<Stream id="8819" streamType="2" selected="1" codec="dca" index="2" channels="8" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="7.1" bitDepth="24" profile="ma" samplingRate="48000" title="English DTS-HD MA 7.1"/>
<Stream id="8820" streamType="3" default="1" forced="1" codec="vobsub" index="3" language="ไทย" languageCode="tha"/>
<Stream id="8821" streamType="3" codec="vobsub" index="4" language="ไทย" languageCode="tha" title="Thai 480p"/>
<Stream id="8822" streamType="3" codec="vobsub" index="5" language="ไทย" languageCode="tha" title="Thai 720p"/>
<Stream id="8823" streamType="3" codec="vobsub" index="6" language="ไทย" languageCode="tha" title="Thai 1080p"/>
<Stream id="8824" streamType="3" selected="1" codec="vobsub" index="7" language="ไทย" languageCode="tha" title="Thai 1080p Yellow"/>
<Stream id="8825" streamType="3" codec="vobsub" index="8" language="ไทย" languageCode="tha" title="Thai 1080p Out"/>
<Stream id="8826" streamType="3" codec="vobsub" index="9" language="ไทย" languageCode="tha" title="Thai 1080p BIG"/>
<Stream id="8827" streamType="3" codec="pgs" index="10" language="ไทย" languageCode="tha" title="Thai PGS BluRay Master"/>
<Stream id="8828" streamType="3" codec="pgs" index="11" language="ไทย" languageCode="tha" title="Thai PGS Out"/>
<Stream id="8829" streamType="3" codec="vobsub" index="12" language="English" languageCode="eng" title="English"/>
</Part>
</Media>
</Video>
</MediaContainer>
Moderator Edit: Applied Code Paragraph formatting to make XML visible and removed non-important part of of XML
Send it again.
Thank you.
The reason you’re having problems are because this subtitle track is forced.
This mandates the transcoder start. Your CPU doesn’t have the power to process VOBSUB (image format which must be re-encoded into the video stream) and still keep up with real-time playback requirement . It does as much as it can, as fast as it can, but it’s not enough.
The CPU in your NAS is capable of hardware transcoding to help with this but without a Plex Pass, it’s unavailable to you.
Should you decide to to subscribe as a trial (one month), do the following if you didn’t download Plex from plex.tv/downloads.
  1. Stop Plex
  2. Uninstall the package (Your library will be safe)
  3. Download the 64 bit package for Synology
  4. Perform a ‘Manual Install’ in Package Center
  5. Settings - Server - General - sign out and then sign the server back in . This activates your Plex Pass.
  6. Play the movie again and enjoy
Thank you for your support.
