DS918+ and Plex directplay is slow to start
Server Version#: 3.69.1
Player Version#: Latest iOS
Both my old DS718+ and now my DS918+ suffers from this issue. Videos that are compatible with iOS (h264) that WILL play without any transcoding, takes forever (well, a few minutes anyway) to start to play (not always but very often)! Watching the spinner for a few minutes is a bit annoying.
Forcing to transcode (I use hardware transcoding) I think seems to work better.
I’ve never experienced any issues with the webplayer (Chrome. Anyway, this problem only occurs on my iPhone8/iPad 2018 with iOS12, and I’ve had the problem for months.
I don’t have any logs at the moment but will try to get them. I can’t be the only one with this issue or can I? I think it’s strange I had it on my previous DS718+ aswell…?
I know I don’t have any logs but anyone have any hints for me?
Network speed or the number of other apps versus memory installed.
Something very basic is wrong.
I’ve got 12GB in my NAS so I don’t think that’s the problem. Is there a clever way to see if something’s bad about my network?
The 918+ has 4GB default upgradable to 8GB.
How do you have 12GB installed ?
It can actually be upgraded to 16GB no matter what Synology say. I’ve added an 8GB RAM module to the empty slot.
I’ve checked some logs now, can I pm someone complete logs?
“Despicable Me 3 (2017): no direct play video profile exists for http/mkv/h264”
Oct 14, 2018 16:11:30.213 [0x7fd80b447700] DEBUG - MDE: Despicable Me 3 (2017): no direct play video profile exists for http/mkv/h264/dca
Oct 14, 2018 16:11:30.213 [0x7fd80b447700] DEBUG - MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
Oct 14, 2018 16:11:30.214 [0x7fd80b447700] DEBUG - MDE: Despicable Me 3 (2017): selected media 0 / 11235
Oct 14, 2018 16:11:30.214 [0x7fd80b447700] DEBUG - Streaming Resource: Reached Decision id=11655 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. No direct play video profile exists for protocol http, with container mkv, and video codec h264. Transcode=1001,Direct play not available; Conversion OK.) media=(id=11235 part=(id=11296 decision=transcode container=mpegts protocol=hls streams=(Video=(id=7392 decision=copy width=1920 height=804) Audio=(id=7393 decision=transcode bitrate=258 encoder=aac channels=2 rate=48000))))
Let me put this to rest once and for all.
The J3455 CPU can only USE 8GB of RAM.
You can install up to 16GB, which Linux is fooled with and DSM displays (it reads the spec for each DIMM and displays the sum).
DSM (Linux) WILL NOT USE MORE THAN 8GB
ref: https://ark.intel.com/products/95594/Intel-Celeron-Processor-J3455-2M-Cache-up-to-2-3-GHz-
Should you overload it with RAM, all types of evil, including corrupted storage volume can occur.
Best action by Synology would be to clamp this value but they have not yet done so
Regarding PMS. The log fragment is not sufficient.
May I request:
  1. DEBUG logs (as you have them)
  2. Start playback,
  3. Let it stream for 30 seconds
  4. Stop Playback
  5. Wait 30 seconds
  6. Settings - Server - Download Logs
  7. Attach the ZIP file
It don’t always playback, it sometimes just stops with an errormessage (sorry, don’t have it right now), sometimes it plays after a minute or two or more… I’ll see if I can get some better logs.
Whatever you need do to recreate it is fine. Whichever works best.
All I ask is you let everything quiesce before pulling the ZIP file.
I then will get a full picture of everything
I’ve sent you a PM with attached logs. I’ll try get more logs from similar scenarios. I will be very interested to hear what you discover.
Thanks in advance.
oRBIT,
This isn’t a directplay situation.
You have an AC3 codec involved and AAC is the only thing the profile for the device allows.
Oct 14, 2018 21:05:36.443 [0x7fd80cfff700] DEBUG - MDE: Cannot direct stream audio stream due to codec ac3 when profile only allows aac
Is the client locked to DirectPlay only?
Now I’m going to ask regarding the NAS itself. Does this Syno have 8 or 16 GB in it?
No it’s not locked to directplay. I think its strange that it doesn’t work and then work a minute later and I haven’t changed a setting.
The NAS has 12GB (4+8).
Kindly reduce the NAS to it’s Intel-spec 8GB.
What happens to Linux when it thinks it has more than the CPU can physically address is this scenario:
  1. OS and main buffers start in low memory (0-2GB)
  2. Temporary memory usage (stack) starts at the top).
  3. Modular math truncates the bits above what the CPU can physically address.
  4. Therefore, Logical address 8GB + 1 is actually physical memory address 1.
    ( the ‘8’ GB bit isn’t present to support the physical addressing of the location )
  5. You actually have 4GB of overlapping or unused memory (depends on the vendor)
Doing sort of an experiment at the moment typing this… Playing back a 1080p HEVC on my iPad from Plex, running a VMM with 8GB RAM running Windows 7, playing a 1080p mediafile through Windows explorer, playing around with DSM at the same time, used memory is about 86% right now. I am no expert whatsoever concerning this, but wouldn’t something crash terribly if I only had access to 8GB?
When you hit the wrong kernel tables it absolutely will.
If the displayed value is cosmetic, then everyone is being fooled and DSM is really keeping track of the 8GB hard limit
However with all memory on one DIMM, you have slower performance than if 2x 4GB due to the lack of dual channel memory mode
Here’s some more RAM discussion concerning DS918+ and amount of RAM. Comments? https://forum.synology.com/enu/viewtopic.php?t=135514
Undestood but the chip maker themselves, Intel, clearly states.
FWIW, I have developed in the kernel itself.
I know how the SPD chip (size and speed settings) is read.
The amount of installed RAM is simply ADDED from the reported values of the SPD chips.
Perhaps going a bit offtopic now, but just wondering about people posting in that forum, here’s quote below. Have they got it wrong?
" For the 3rd time, it’s 8GB/channel so 16GB total
Have a look at the AsRock J3455 board specs, it’s exactly the same CPU.
http://asrock.com/mb/Intel/J3455-ITX/?c … ifications
  • Max. capacity of system memory: 16GB"
