I had no idea that 8GB is the sweet spot for hardware transcoding! The current QNAP model (TS-453Be) only offers options of 2GB and 4GB, which is a real shame. But a quick browse of the forums shows most people upgrading to 8GB using Crucial memory. QNAP technically says 8GB is the max, but it seems fairly common to upgrade to 2x8GB modules and multiple people report that it works fine. Hmm, decisions.
Also, just to be clear: I’m incredibly jealous of your NAS setup.
The J3455 maxes out at 8GB. That being the case; get the 2GB and also get the correct spec memory as a 8GB Kit (which makes it a matched pair) as aftermarket. Don’t fall into the Mhz game. Get what the spec is for the bus and then the lowest CL (CAS latency) you can find and afford.
You want memory on the correct clock spec because the bus doesn’t clock any faster just because the memory can but if the memory is high latency, the CPU will be wait-stated while it gets the data.
A 2x4GB kit from Crucial will almost definitely be the winner, in that case. It costs only a little more than the difference between a 2GB and 4GB model, so that saves some money. I’ll make sure to nail the specs, and will focus on the lowest reasonable CL possible. Thanks for doing the footwork on this one and making sure I got it right.
So it’s clear what Intel calls for memory spec: (Always consult the Intel spec)
Memory Specifications
Max Memory Size (dependent on memory type): 8 GB
Memory Types: DDR3L/LPDDR3 up to 1866 MT/s; LPDDR4 up to 2400 MT/s
Max # of Memory Channels: 2
ECC Memory Supported: No
