I have a serious problem. I setup an account wityh Plex. When I play the films in the web player and through the Plex Media Server app on the sonology, It’s all fluent. But watching it on my Sony XE90 TV either through the android plex app or chromecasting from web to TV, It buffers every 4 seconds and is unusable.
Plex, downloaded from Synology in Package Center is 32 bits only. They do not provide the 64 bit version. Performing manual install from Plex, if you selected it, is the 64 bit version.
Hardware transcoding requires an active Plex Pass subscription to enable.
Synology, unfortunately, is VERY slow at updating the plex package they host. I always grab mine straight from plex themselves. More recent versions have a feature that helps you keep it up to date. When you open your plex server in a web client as yourself, it adds a banner to the top if there is a newer version available. The banner includes a link to the exact file you want. Then you just do a manual package install on top of the current version, very quick and simple to do.
I used MAKEMKV to rip the files. Didn’t change anything except selecting the sound tracks and subtitles that I wanted. Otherwise left it untouched. What is it that Plex doesn’t like here? I used MAKEMKV to keep the digital copies lossless.
Please, for future reference Do not enable VERBOSE logging until requested it makes my job much more difficult and information is often lost. VERBOSE outputs information on every single mouse click and streamed packet. WAY too much information at this level of diagnosis
May I have the XML for the file? (Hover over it - > Get Info -> View XML)
If this is the file you’re attempting to play, here’s why
Mar 06, 2018 09:29:31.577 [0x7f6bb5959700] DEBUG - MDE: Selected protocol dash; container: mp4
Mar 06, 2018 09:29:31.577 [0x7f6bb5959700] DEBUG - MDE: analyzing media item 943
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Casino Royale (2006): Direct Play is disabled
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Casino Royale (2006): media must be transcoded in order to use the dash protocol
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Casino Royale (2006): no direct play video profile exists for http/mkv/h264
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Casino Royale (2006): no direct play video profile exists for http/mkv/h264/dca
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
Mar 06, 2018 09:29:31.578 [0x7f6bb5959700] DEBUG - MDE: Casino Royale (2006): selected media 0 / 943
Mar 06, 2018 09:29:31.579 [0x7f6bb5959700] DEBUG - Streaming Resource: Added session %p:ea3xmpwsbe7iliw82kjlkkv9
Mar 06, 2018 09:29:31.579 [0x7f6bb5959700] DEBUG - Streaming Resource: Reached Decision id=697 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=943 part=(id=963 decision=transcode container=mp4 protocol=dash streams=(Video=(id=1871 decision=copy width=1920 height=1080) Audio=(id=1872 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
The player app is stereo and not multi-channel. MDE: Cannot direct stream audio stream due to codec dca when profile only allows aac
It must convert the audio
It must convert the MKV -> MP4
If there are subtitles (which I cannot see here yet), they must be processed (why I need the XML)
You do not have an active Plex Pass and can’t use hardware transcoding. This looks like more work than the CPU is capable of. (BIG problem on all Synology systems, including mine)
Hi, what does ‘profile’ mean in the sentence you showed?
Can that profile be found on Plex server?
Can I modify it to update relations between what TV can receive and Plex can provide to decrease amount of cases where “item is not playable because server is not powerful enough”.
If I improve rules for Plex Transcode I guess it will give some positive result.
What that shows me is there are no defined conditions (video + audio = DirectPlay on your device) as part of the first level decision.
Plex apps can, and do, add additional capabilities when they detect them .
An good example of this is an AppleTV 4K connected to a 2K (1080P) television and another connected to a 4K (2160P) television and you wanting to play 4K on both
Both apps start up. One sees 1080p and the other sees 2160p capability.
When you go to play, PMS looks at the ATV profile and says “No 4K capability found” but, since there’s a 4K TV connected, the app comes back with “4K capable”. PMS takes this profile augmentation information and comes to the final decision. When there is profile augmentation such as this, it will show in the log. I didn’t find it in your logs.
Regarding modifying profiles:
You can take the existing Plex template profiles (under Resources/Profiles, which you’ll have to go into the @appstore on the command line level to get to and copy somewhere for editing), find the one which fits best, and start editing. When done, it will be placed in Plex/Library/Application Support/Plex Media Server/Profiles with the name for your TV (Sony.xml and in the device identifier ). Be advised, figuring out the name is hit or miss and usually takes a bit of experimentation. Each time you change the profile, you must restart PMS (Profiles are loaded into memory upon first use).
Cautions:
The Sony can’t handle DirectPlay. There are several models which can’t (Audio codec)
Running PMS w/ transcoding in 4GB on a Syno is getting tight on memory especially if running other things. It works a lot better with 8GB. If you had a Plex Pass, your CPU load would drop to ~25-30% instantly for all but HEVC UHD (some hover around 50% for that). Many users have found 8GB to be the sweet spot for Hardware Transcoding on Synology.
Still no luck with the Blu-rays I ripped to MKV using MakeMKV. Not even with a press pass and hw transcoding (I signed up for a free month of plex Pass. Playing a 19 GB MKV file of Despecialized Star Wars A New Hope with flawlessly, though.
I’m scraping my hair as to why MakeMKV would, by default, generate MKV files incompatible with streaming services / programs. What on Earth is that makes an MKV H264 incompatible with Synology Video Station and Plex when a Handbraked lossy vers. Works???
excellent. thank you. at some point, you will want to sign out of the forum and back in there too. It will give you access to the Plex Pass section of the forum.
In Settings - Server - Transcoder, you enabled Use hardware acceleration when available
There is one established issue with Synology. It is trivial to fix
If DSM is updated after Plex is installed, it erases the hardware settings I establish for hardware transcoding.
The correction for this is simple. It does not harm your library (metadata) in any way.
Uninstall Plex in Package Center
Reinstall Plex (using Manual Install) again.
This works because I write the rules each time I install. I assume nothing and write them regardless. If they exist, I update them
Now you can try hardware transcoding again for H.264 video.
If you still have difficulty, Stop playback, Settings - Server - Help - Download Logs and attach the ZIP file it gives you here with your next post
