DSD/DSF files - wrong rate
I have some DSF files that contain DSD64 audio. When I stream them in plexamp they get converted to 352 kHz, when 176 kHz (or even 88.2) would be better choices.
When I get info on the files in Plex, the bitrate is reported as 5645 kbps and the sampling rate as 352 kHz. The bitrate should be 2822 kbps. I’m guessing if the bitrate was properly identified, a more appropriate sampling rate would be chosen.
Any idea how I can correct this?
