Getting only 44.1kHz for DSD or FLAC 24bit
I have tried a DSD and 24bit flacs on my external USB DAC but I always get the 44.1kHz! when I use DSD it should change to colour Cyan or Red as per iFi Zen Dac v2, I normaly use Audirvana and with the same files everything works as it should but not in plexamp!!!
Screenshot 2022-01-15 at 22.06.36
Screenshot 2022-01-15 at 22.06.21
Plexamp has no support for DSD whatsoever. Therefore everything in DSD is transcoded to PCM.
The bit depth has nothing to do with the sample rate, btw.
to clarify, it supports DSD in that plexamp itself decodes to PCM (which offers numerous advantages compared to passing it through).
make sure you have sample rate matching enabled.
Ahhhh, ok, thats good to know, since I read that it supports DSD and I thought it would just pass through, thanks.
