Server Version: 1.23.5.4801
Player Version: 8.20.0.26605 (781d3db5)
I have the new Sony A90J TV, and an old Sony CT780 Soundbar. I’m currently using Plex installed on the Google TV, the Soundbar is connected to the TV through the ARC/eARC port, and the “passthrough” option in the Plex Android app is set to “HDMI”.
Here’s the audio formats supported by my Soundbar:
When I play a video file with TrueHD, Plex transcodes this to AAC, because the TV itself can’t passthrough TrueHD to the Soundbar (apparently no TV in the market can). So far so good, but… When I play a video file with DTS-HD MA, the audio is constantly cracking/popping. I don’t think this is supposed to happen.
In an attempt to debug/fix the issue, I’ve changed the “passthrough” option in the Plex Android app to “Disable”, and I no longer have crackling/popping sound for DTS-HD MA audio streams; however, Plex changed from Direct Play to Direct Stream. Not a dealbreaker for me, but the interesting thing here is that there is no transcoding, not even for the audio track.
So, I’ve disabled passthrough, Plex uses Direct Stream, but sends both the audio and video tracks to the Soundbar/TV without any transcoding whatsover, and the DTS-D MA tracks plays without issues.
If Plex isn’t transcoding when passthrough is disabled, shouldn’t it be able to play the DTS-HD MA audio track with passthrough enabled without any crackling/popping sounds? What am I missing?
