Dual audio option
Dear users,
I'm trying to enable dual audio using the dual audio option within the guesettings.xml. Unfortunately, the guisettings.xml is always being rolled back on boot. Also when I edit it on a running raspberry, and when it's off, on the SD card.
I'm adding the following line to the end of the audiooutput section in the XML file.
true
What I'm doing wrong, or is there any way to add this to the GUI itself as a option?
Thanks,
Wouter0100
Dear users,
true
Thanks,
Wouter0100
This option is not supported or documented for Rasplex, if you feel this is a needed enhancement please open a request for enhancement on Github, see sticky for how to do this.
Regards
