Is there a feature request in queue for mass duplicate removal? because it’s great how Plex can filter duplicate movies/tv episodes but it does me no good if I have 1,100 duplicates and I have to remove them one-by-one. Can’t you guys add some intelligence behind this for doing remove all based on age, quality, or something?
Well… it might be – if you can be sure it’s not just mismatched movies showing up as duplicates.
1,100 duplicates is a lot… how confident are you that’s actually duplicates and no bad matches (e.g. due to bad file naming etc.)?
… or a folder accidentally wrongly included in another library section. ?
