Duplicate set of actors and directors from newer matches
Server Version#:1.25.1.5286-700
Player Version#:All platforms all versions
This seems to be from new content I have added but there have been movies I know have actors in other content I own and I have not found them in there. Upon searching for that actor, the name appears twice. I did some checking and it seems to be with directors, too. Specifically, I pulled in Jingle All the Way 2 with Larry the Cable Guy and I found that that actor in that movie just showed up for that movie. A different “Larry the Cable Guy” showed up on all my Cars movies. The same thing with the director Brian Henson. I just added Muppet Christmas Carol and that Brian Henson as the directory did not include the other Muppets movies I have.
It is acting as if there would be a duplicate movie or song where I would have to split them apart but since that is not a part of this, I cannot do that.
Basically, it is not linking the actors and directors to existing content I already have on my server during the Match process.
It is only happening with new content but it is happening with all new content I add.
I tried unmatching or fix match’ing the movie but that did not fix the problem.
I really cannot think of a good set of search terms to browse the forum so I apologize if this has been asked. Nothing is showing up in the suggestions.
If anyone has any suggestions, thank you in advance.
You’re late to the show. :wink:
Plex have already commented on that some time ago. There’s been some changes in how they handle actors/directors (to the better) – refreshing the library’s metadata will fix this hiccup right away, otherwise you can simply wait for certain scheduled maintenance tasks to happen.
Thank you. That did the trick
Thx. Much appreciated. First search of the PLEX forums and your answer gave me exactly what I was looking for.
