Still confused by this one … somehow the DVR is storing information that goes away on refresh (i.e. the filename is not sufficient?)? And also, shows that should be grouped together are still showing up separately.
Thoughts?
Thanks!
Thoughts?
Thanks!
I too am having a similar issue. Every DVR recording creates TWO identical entries in the dashboard in Plex although often with different cover art image. I do have Plex optimization on as well which means that I watch these server perform TWO optimizations as well, one for each file.
FYI, still seeing this - and I’m running 1.7.4 (the latest). It seemed to perhaps go away at one point, but it’s back … :(. Any suggestions? And this is even for only items recorded with the DVR.
Thanks!
BTW, still seeing this … :(. And as well, if I copy a file right over top of itself, same name exactly - I seem to lose the show information inside Plex. Makes no sense to me - any thoughts?
