In my TV Shows Library I have an issue :
As you can see, the same Show appears multiple times. For example for Suits the first one contains only Season 5 and the second contains 1,3,4
Did a make a configuration mistake ?
Thanks !
Thanks !
Most likely, yes.
§ : % *, simply leave them out.Show's Title - s01e01 - additional info.ext (‘- additional info’ can be left out)Following the naming standerd of Plex is crucial for avoiding this type of issue.
Do also check if your files are in mp4/m4v format.
If they are, they could contain internal ‘metadata’ which can potentially throw off Plex’s scanners.
To avoid such troubles, go to Settings - Server - Agents - Shows -TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack active agents.
